My living room to spec is 24X13.5. Was wondering what kind of recessed light configuration would be best with a fan in the middle of the room. The lights are 4500k led lights. Let me know y’alls thoughts are.
If you want to step it a notch above DIY, consider the layout of your furniture and circulation routes. Your seating area is probably around 16'x13.5', and the tv wall dictates orientation. Plan your ceiling fan and light layout based on that.
A option to consider is adding track lighting as these allow you to change the placement of the lights on the track. Only need one power connection for the entire track and it is surface mounted.
Problem with recessed lights is that the layout will be fixed and the furniture layout will be as well. Not a problem in a kitchen, bathroom, or for general lighting at the edges of a room with a tall ceiling, but not great for lighting a seating area.
There are projection type recessed lights and they allow for directing the light but they are also a lot more expensive.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
