Rebar In Interior Basement Wall - Is It Load Bearing? - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-15-2015, 07:40 PM   #1
Rewards Points: 6
Rebar in interior basement wall - is it load bearing?
I recently started demo on an interior basement wall. It is parallel with the floor trusses above so I figured it wasn't load bearing. Now that I've begun demo I've found rebar in the cement along the wall (every 20 inches or so). Around the door it's connected to 2x4's but otherwise the rebar just sits in the wall attached to nothing but the floor. Does this mean it's load bearing? Do I need to cease demo or can I cut out the rebar?
I've included a picture of the wall (it has a few holes in it). You can see it joins with a metal support beam that runs perpendicular to the floor joists.
jodixo is offline   Reply With Quote
Old 09-15-2015, 08:23 PM   #2
Concrete & Masonry
Rewards Points: 314
That looks like a wood franmed wall with drywall covering? You found rebar inside of THAT?
jomama45 is offline   Reply With Quote
Old 09-15-2015, 08:26 PM   #3
Rewards Points: 6
Yes, it's wood framed and the rebar is coming out of the cement foundation. As far as I can tell it only comes up about 6 inches from the cement.
Old 09-15-2015, 08:33 PM   #4
Concrete & Masonry
Rewards Points: 314
I've never seen that in my career before. Perhaps it was some "shade-tree" attempt at anchoring down the bottom plate to the concrete floor?? Either way, I wouldn't worry about the rebar.........
The Following User Says Thank You to jomama45 For This Useful Post:
jodixo (09-15-2015)
Old 09-15-2015, 08:34 PM   #5
Rewards Points: 6
So the rebar is not an indication of a load-bearing wall?
Old 09-19-2015, 04:54 PM   #6
Rewards Points: 2,452
Could it be some kind of brace wall? You should know more about its history before you move it. May be a bunker.
carpdad is offline   Reply With Quote
Old 09-19-2015, 06:11 PM   #7
Rewards Points: 5,348
Do you have photos of the wall after demo. With the rebar?
Ron
B. Franklin 1759
Load Bearing wall? ssgtjoenunez Building & Construction 12 03-01-2013 06:03 PM
Load bearing wall? renntecher Building & Construction 2 02-04-2013 01:35 AM
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 05:35 PM
Is this Load Bearing Wall remodel-virgin Building & Construction 16 05-11-2009 04:25 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
