Re-Surfacing: Peel Up Lminate / Veneer Or Glue On New - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-24-2015, 10:49 PM   #1
Rewards Points: 315
Re-Surfacing: Peel up Lminate / Veneer or Glue on New
So we've got this old cabinet / shelving unit that has what to us is a hideous top and sides. It's some kind of laminate over what appears to be a cheap hardwood of some sort.
I'm thinking we can re-purpose it, but I' not sure if I should try to peel the existing stuff off or just re-install something over the top of it. The current surface is in good shape and I'm leaning towards putting something on top since it's already smooth. If I chip it off, I'm all but guaranteed to end up with some uneven spots that may be challenging to level out.
Anyone done this before?
Thoughts?
Thanks.
cabinet-laminate1 by ScottGPics, on Flickr
cabinet-laminate2 by ScottGPics, on Flickr
Scottg is offline   Reply With Quote
Old 09-15-2015, 11:48 PM   #2
Rewards Points: 315
Not that anyone's replied - so maybe no one cares - but just in case anyone faces similar...
I ended up lightly sanding this. Then gave it two coats of Zinser 2 primer, then two coats of beige latex followed by some polyacrylic. Looks great.
Also added some bypass tracks for the front and cut some doors out of 1/4 MDF. Will take an 'after' pic when I get a chance.
The Following User Says Thank You to Scottg For This Useful Post:
Gymschu (09-16-2015)
Old 09-16-2015, 08:50 AM   #3
Super Moderator
Gymschu's Avatar
Rewards Points: 6,742
I've had success with RustOleum's Counter top paint.
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 09-19-2015, 04:48 PM   #4
Rewards Points: 2,438
Acetone and craft syringe will dissolve the formica glue. No trouble at all. Then you can veneer with formica or wood veneer. Paint is not a durable countertop finish.
Properly roughed up formica will take new glued sheets but the edge beveling may not work. I never had to bevel 2 ply edge.
carpdad is offline   Reply With Quote
OSB or plywood? Glue or no glue? Truckerswife Flooring 7 03-27-2011 09:30 PM
carpet glue pfmartin0387 Flooring 1 10-03-2010 08:17 PM
do i have to remove old adhesive glue on wall for new ceramic with glue? Limit54 Tiling, ceramics, marble 2 03-01-2010 10:12 PM
glue to a mirror Leprichon Interior Decorating 9 04-19-2009 02:16 AM
Wood Glue Issue gp1200r Carpentry 4 02-20-2008 11:56 AM
