Re-purposing Kitchen Cabinets In My Garage - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-13-2013, 12:33 PM   #1
Question
Re-purposing Kitchen cabinets in my Garage
Hi guys,
I just acquired the wall mounted cabinet pieces in the photo I included and I want to mount them in my garage for storage. The pieces are all solid but not too heavy besides the piece with the slots. The garage isn't finished (aka: the studs are visible). I've never done this before and I want to do this as cheaply as I can. Looking for recommendations on how to mount them securely in my garage.
Thanks for the help!!
Mitch
mwilson76 is offline   Reply With Quote
Old 11-13-2013, 03:21 PM   #2
Rewards Points: 17,884
What's the plans for the garage?
Before anything goes in I'd install all the wiring over the cabinet.
Your going to want to add outlets over those bottom cabinets.
Insulate, sheetrock then install the cabinets.
Old 11-14-2013, 07:02 AM   #3
No plans to insulate and sheetrock the garage, and there are outlets already in place. I only took the two bottom cabinets on the left in the picture. I'm going to mount the cabinets directly to the studs and I'm considering stacking the cabinets in some fashion to take up space in just a section of the garage. Any ideas are appreciated. Thanks joecaption for the feedback!
Old 11-14-2013, 08:04 AM   #4
I would first attach a 1 X 4 board across the 2X's at the height of the where the backer is inside the cabinet so you will have something to screw to.
If those are just particle board cabinets I would flip the cabinet before installing and install some plastic nail on chair leg protectors.
Particle board can soak up moisture like a sponge.
http://www.alliance-express.com/tack-glides
Old 11-14-2013, 11:56 AM   #5
Bill Kearney
Rewards Points: 1,174
The upside to insulating and drywalling the garage is keeping the moisture from wrecking the cabinets... Otherwise the space between them and the wall becomes a point for moisture to develop. Exceptions might be if you're in a bone-dry climate, which updating your profile with a location would help determine...
wkearney99 is offline   Reply With Quote
Old 11-17-2013, 01:17 PM   #6
Rewards Points: 636
set first wall cabinet screwed to stud, set next cabinet fastened to stud then fasten cabinets together with thru bolts (use 4 bolts top and bottom front and back). then repeat as long as each cabinet hits one stud it will be solid
https://www.google.com/search?q=cabi...w=1600&bih=775
i like these screws for hanging that type of cabinet
http://www.fastcap.com/estore/pc/Pow...tal-p13284.htm
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Tags
cheap , garage storage , kitchen cabinets , mounting cabinets , re-purposing
Removing soffit above kitchen cabinets somecallmemike Kitchen & Bath Remodeling 17 09-27-2012 12:37 PM
Antiquing kitchen cabinets Beeba Painting 1 09-17-2012 07:22 PM
Upper Kitchen Cabinets latemoy Carpentry 3 09-13-2011 06:31 AM
installing used kitchen cabinets xcuter Kitchen & Bath Remodeling 1 07-19-2010 01:39 PM
diy built-in kitchen cabinets Jeremy Hillary Boob, PhD Carpentry 6 11-29-2008 11:46 PM
