Range Vent Install - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-21-2014, 12:39 PM   #1
Rewards Points: 866
Range Vent Install
Our home was built with a down draft vent for a Jenn Air cook top, but we want to install venting for a range hood. That vent can access an exterior wall some 8 feet away via a soffit, but passage through the wall is there blocked by existing water supply pipes and ABS cleanout and waste lines.
Is it legal to then travel down a vertical soffit, which would have to be enlarged in one dimension, to a point where the range vent can connect with the existing vent for the down draft? To do all of this will require a total of 5 turns.
Attached are some pictures. One shows the existing downdraft venting and blower. The net shows the horizontal and vertical soffits. The last is the existing vent that I hope to connect with.
Range Vent Install-venting-009.jpg   Range Vent Install-venting-010.jpg   Range Vent Install-venting-011.jpg
Klawman is offline   Reply With Quote
Old 08-23-2014, 07:20 AM   #2
Rewards Points: 2,490
I have IRC 2000, and it doesn't say much about the range hoods, except follow the hood makers instruction. Search the models and their manuals. Most I found in past was duct sizing, but as far as fire code, their manual usually say refer to the local code.
I think certain gauge metal duct and sealed joint would pass the inspection.
The distance and the turns would stop any inspector, though, knowledgeable diy or a professional. I think 5 is too many turns except for industrial model fans, or you'd have to use the highest fan setting and cook while there is a hurricane blowing above you. Remember that you are burying that pipe.
How about going directly through the wall and build a drop ceiling in the room opposite the tile wall? Then go to the exterior wall?
Any case, my thoughts on a next kitchen would be using a combination hood (with light and switches) with an exterior motor and fan. Fantech has at least the fan housing that's hung outside.
carpdad is offline   Reply With Quote
Old 08-25-2014, 07:28 AM   #3
Rewards Points: 3,130
I think five turns and the length you want to go are way too much. It'd make a built-in grease trap, not to mention fire hazard. There's a reason most stoves are on an exterior wall.
Can't say exactly what it should be, but you need some other plan.
Old 08-25-2014, 07:42 AM   #4
Retired Moderator
Rewards Points: 7,174
Consider an exterior exhaust fan---those pull the air through the duct---still--5 90's is a lot of resistance.
Kitchen range install and backerboard on tile floor joemc3 Flooring 4 07-17-2013 06:43 AM
what is the best way to seal an old unused range vent duct? jimnsulaw17 General DIY Discussions 1 11-21-2010 07:11 AM
Elecrolux slide-in range install help RickC General DIY Discussions 5 04-07-2010 08:29 PM
Range hood install questions drtbk4ever Building & Construction 6 10-09-2009 09:00 AM
Proper way to install half round dormer vent? Git Roofing/Siding 12 07-31-2009 05:33 PM
