Quick Question Regarding Window Placement And Etc.. - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-03-2013, 12:44 PM   #1
Quick question regarding window placement and etc..
Hello Guys and Gals,
I have a kitchen thats part of an entire house remodel. I would like to put the window above the sink like the picture below. I do not have "Solid Wood Flooring" picked out nor the cabinets/countertop. Not even remotely close to that stage.
So from osb/underlayment up how far do I need to go?
Is there a standard countertop/cabinet height?
Thank you for any info. This is my last window and i'd love to put it in so I can put my siding on that side of the house.
DukeLewis87 is offline   Reply With Quote
Old 11-03-2013, 12:45 PM   #2
Picture: ..... Just some random 30second search of a kitchen
Quick question regarding window placement and etc..-kitchen......................................................jpg
Old 11-03-2013, 12:52 PM   #3
Rewards Points: 766
A standard countertop is 36" off the finished floor. 34 1/2" for the base cabinet and 1 1/2" for the counter.
18" from the countertop to the bottom of the upper cabinets.
AandPDan is offline   Reply With Quote
Old 11-03-2013, 12:55 PM   #4
How far would you go to say standard. 95:100 types out there?
And thank you
Old 11-03-2013, 01:01 PM   #5
In a little over my head
Rewards Points: 710
I just measured mine for you. The top of the stool is 6.75" above the counter surface. That barely leaves room for the apron and standard formica backsplash. I might go an inch or two higher if you're doing anything creative with the apron or splash.
ratherbefishing is offline   Reply With Quote
Old 11-03-2013, 02:03 PM   #6
Rewards Points: 766
And thank you
Most ranges are about 35 1/2 or so high. Most dishwashers 34. Both are adjustable to level. The dishwasher fits under the counter. That's probably 95% of kitchens in the country.
Unless you're into commercial stuff you these be OK.
You're welcome.
Old 11-03-2013, 03:30 PM   #7
Went very smoothly for framing and installation. Ty
Old 11-03-2013, 03:33 PM   #8
I would like to do a brick look pattern for backsplash if not real brick if its sold thin enough, and run my counter to it w/o a counter top backsplash/lip/w,e..
Old 11-03-2013, 03:37 PM   #9
Rewards Points: 17,890
Need to install the counter top first then the back splash or water will get in easier and there's going to be gaps any place the mortar goes that will make it more likely to leak.
Old 11-03-2013, 04:09 PM   #10
Ill have to remember that Thank you
20,000 hours/8 months later i think we finally have the floor/walls(Not including rafters) framed. So quite aways away from setting countertops
Old 11-03-2013, 07:21 PM   #11
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,276
I will have a vent pipe running horizontally in the wall behind my sink and have to leave enough height for it.
Just something to think about.
I have my window opening planned at 48" up. This leaves a good foot of back splash.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 11-08-2013, 07:32 AM   #12
Mold!! Let's kill it!
Rewards Points: 2,012
Just keep in mind that brick is going to be very porous and anything that splashes on it is going to soak in and be difficult to clean off. You're likely to have stained brick. Especially near the range where it will be grease splattering it.
