Questions About Sealing My Garage Space - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-05-2014, 10:43 PM   #1
Questions about sealing my garage space
Hey folks I have a garage/apartment remodel that is going to kick off soon. The future apartment is going to be directly above my garage. So, it is necessary for me to seal my garage with an appropriate fire rating etc... Oregon code requires 5/8 rock on the ceiling, 1/2 min. for the walls, and all penetrations must be sealed with a fire rated caulk etc...
The problem that I have is my new furnace and existing ducting are located tight in one corner of the garage. The ducting runs through the ceiling to the upper space (where the apartment will be located).
So, I have no way of installing Sheetrock or sealing the garage in that specific corner. Is it possible to build an interior garage wall that essentially is sealing the space and creating a mechanical room for the furnace? Im sure I will need a fire rated door to the room with the proper seals etc... No worries about the furnace it is a direct vented furnace and draws all of its air from the exterior.
Any comments or points would be great. thanks in advance, Mitch
mitshep is offline   Reply With Quote
Old 09-10-2014, 08:20 AM   #2
Rewards Points: 2,458
If it is direct vented, you may not need to use the existing duct. If you do, you can replace with double walled duct and fire rated enclosure.
carpdad is offline   Reply With Quote
Air Sealing Subfloor Joist Space - Foam Board? masonbrown Insulation 2 05-06-2012 03:54 PM
Crawl Space Questions mark2741 Building & Construction 1 12-23-2011 11:20 PM
Questions about sealing a crawlspace. John_W HVAC 5 07-11-2010 02:24 PM
Are You Wasting Space In Your Garage? BJLower Carpentry 2 10-07-2008 07:54 PM
How to attach this garage and convert it into a living space? BleachCola Building & Construction 16 02-02-2008 03:40 PM
