Question About Installing Beadboard Wainscoting? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-06-2015, 09:21 AM   #1
Rewards Points: 2
question about installing beadboard wainscoting?
Hello everyone! I'm installing bead board panels on the upper part of a wall. I planned on removing all window and shelving trim and the top part of the chair rail and just hiding the panels with the existing trim but ran into a problem where the in wall shelving unit is. If I remove the trim and put back on top of the panels, there will be a gap between the trim and the inside of the shelving unit/windows. My other thought was to leave all of the trim and just bring panels up to them and add some 1/4 round along the trim and on top of the chair rail. Hopefully the pics are helpful (pictured is the top of the chair rail where it meets the right side of the shelving unit)
I'm wondering how you would do it?
thank you
question about installing beadboard wainscoting?-photo-1.jpg   question about installing beadboard wainscoting?-photo-2.jpg   question about installing beadboard wainscoting?-photo-3.jpg
jay137 is offline   Reply With Quote
Old 02-06-2015, 02:13 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
1.) Leave the trim in place and cut the panels 'net' to the trim. You could then close the juncture with a little caulk if you are painting everything.
ALTERNATE PLAN:
2.) You could also remove the trim and extend the jambs with a piece of lattice, install the panels up to the lattice. That seam would then be hidden under the trim when it is reinstalled. Then paint/stain the small edge of the lattice that is exposed.
XXX
Installing shower (tub flange question) Hebobeebler Kitchen & Bath Remodeling 4 10-21-2013 09:28 AM
Installing beadboard panelling as wainscotting KarenSB Carpentry 32 08-10-2013 06:44 AM
Beadboard Wainscoting Down Stairs jimmycrackcode Carpentry 5 02-08-2012 02:21 PM
Question on installing tile pwarther Flooring 3 03-20-2011 04:17 PM
Question on installing pergo stair nose amaruenterprise Carpentry 11 10-11-2009 05:21 PM
