Which Quality Of Pine Lumber For Tongue And Groove Wall? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-02-2015, 10:44 AM   #1
Which Quality of pine lumber for tongue and groove wall?
So I am planning to redo my walls in my living room with pine 1 x 6s or maybe 4s (haven't decided size yet). I am just curious as too what Quality of board I should get because I see they have select, quality and standard. I know quality would obviously be nicer but very costly and I figure they might be more for outside purposes. I don't get much rain in my living room but I don't want to use the cheapest if there is a risk of warping. While you're here I also have been on an extensive search for beginning router bit sets. I know I'll use it for shelving and probably other stuff I venture into learning overtime. I have yet to find a bit set with tongue and groove included.
jbockenfeld is offline   Reply With Quote
Old 01-02-2015, 11:46 AM   #2
Rewards Points: 144
You cab save a few bucks buying router bit sets.I have always bought single bits as the need arises for a certain profile.The sets look less expensive but when you never use half of them,what is the savings?
If you plan on using a tongue and groove set you really need a router table for best results.
I would go with the quality grade pine.The standard grade gets pretty rough.The select has less knots and the color match is better.
mako1 is offline   Reply With Quote
Old 01-02-2015, 02:23 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
clear pine will give you the best results. as it wont have any large loose knots.
if you want some character you can use knotty pine , the only thing is you may need to pick through it a little more to make sure your knot getting loose knots and really unsightly ones full of pitch
woodworkbykirk is offline   Reply With Quote
Old 01-02-2015, 03:14 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,496
This is what I've done over the years, just buy as you need them. I am just the other way when running T&G, I want a hand held router instead if the router table, if a board is off a little the profile can ride down and mess the board up where the router just follows the bend, twist or what ever. JMHO
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-02-2015, 03:23 PM   #5
Rewards Points: 144
That's why I use feather boards on the router table.For me it's just to easy to tip the router when running it by hand.It does not take much with T&G to mess up the joint.
Just my preference.
The Following User Says Thank You to mako1 For This Useful Post:
BigJim (01-02-2015)
Tongue and Groove Interior Wall pogimar Carpentry 7 06-23-2013 04:53 PM
Yellow Pine tongue n groove Porch creek07 Painting 4 07-03-2012 09:56 PM
How to match pine tongue and groove wall Roadking305 Carpentry 1 08-09-2011 09:15 AM
milling own pine tongue and groove chulett General DIY Discussions 24 06-06-2011 09:58 PM
How to get wiring into wall with tongue and groove panels npn_ Electrical 4 03-05-2011 04:52 PM
