Purlin Supports/ Load Bearing Wall Removal - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By jlhaslip
Old 03-16-2017, 08:16 PM   #1
Rewards Points: 2
purlin supports/ Load bearing wall removal
I am removing a load bearing wall that is 85 in length. The ceiling joist run perpendicular to the wall, and I have an lvl beam running on to and perpendicular to the joists. I also have purlin supports that are in the wat by about an 1. What is the best and safest fix for this? Can I cut a 1 notch out of the supports? Do the supports have to be moved and fastened to the beam?
trlmix is offline   Reply With Quote
Old 03-16-2017, 08:29 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: purlin supports/ Load bearing wall removal
Might need a picture of this one.
Str8AheadInc likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
Str8AheadInc (04-02-2017)
Old 04-02-2017, 06:59 PM   #3
Professional
Rewards Points: 188
The wording is tough to follow. Have you removed the wall? Not sure what you mean by "What is the safest fix for this?"
Post a pic, I've removed some walls and would love to take a look.
Str8AheadInc is offline   Reply With Quote
Old 04-02-2017, 07:45 PM   #4
Registered User
Rewards Points: 526
-----------------------------Welcome to the forums!----------------------
Any struts have to terminate on top the beam, not the side, and in the same plane- without engineering. And strut angle cannot be less than a 45* so you may need to lower the upset beam below the ceiling and add a post/column; pp.95/105; http://www.ce.udel.edu/courses/CIEG4...%20-%20IBC.pdf
Gary
Tags
load bearing wall , purlin supports
Seems someone broke my my load bearing wall karras Building & Construction 1 12-09-2016 02:31 PM
wall removal... load bearing? interesting find jaxm211 Remodeling 6 08-07-2015 08:53 AM
Load Bearing Wall? Master Brian Building & Construction 3 06-05-2015 10:32 PM
Load bearing wall? renntecher Building & Construction 2 02-04-2013 01:35 AM
Wine rack as load bearing wall? lisa7932 Building & Construction 5 02-27-2012 12:53 AM
