Post Removal In A Weight Bearing Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-22-2013, 07:22 PM   #1
post removal in a weight bearing wall
There is an addition that is 24 feet wide with a post directly in the middle. The post really interferes with the flow of the rooms (den/kitchen/dr combo area). Can it be removed and how expensive is it to remove a post. It does have a light switch in it.
gemrnbsn is offline   Reply With Quote
Old 11-22-2013, 08:16 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 9,258
Your not going to like the answer......
Yes....it 'can' be removed....but you need the input from an engineer. Is this single story or 2-story?
It's not expensive to remove it.....it's the cost of putting a beam up there to support the weight for that span that is expensive.
I can understand why you want to remove it.....but if your asking price....chances are, once you find out what it will cost to 'eliminate', your going to like that post a lot more.
Just to give you an idea of what would be needed....my garage is 20' wide...I have a PSL beam that is 16"H x 7"W across that span. I'm sure your room would need a larger one (that can only be determined by an engineer). BTW....my garage is 2-stories...
In addition....it needs to be determined if your outside foundation can support the additional weight created by the beam at the ends.
Lastly....you will not get anyone here to give you a price....too many variables.
Good luck....and...it would be nice for you to post up what you find out....it might help someone else.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
rossfingal (11-23-2013)
Old 11-23-2013, 09:00 AM   #3
K&B Designer
Live_Oak's Avatar
Talk to a structural engineer about the hows of removing the post and reengineering the home's support system. That's typically an inexpensive (in the world of construction) expenditure. You will need his plans to file with your AHJ to get the permit. The beam that will be needed will be pretty large, and the skill set to set it is beyond the skill of most casual DIYers, so once you get the engineer's report, you can talk to contractors with that information in hand to be able to get a price for what the engineer has recommended. There's no such thing as a "typical" project or price for such a project, as it could vary from 2K in a low cost labor area with low weight loads that can use the existing foundation to 20K in a higher cost labor area with high weight loads and a newly engineered piers for the point loads.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Tags
post removal
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Load bearing wall removal abjkkc Building & Construction 17 10-03-2012 10:49 AM
Wine rack as load bearing wall? lisa7932 Building & Construction 5 02-27-2012 12:53 AM
Load bearing wall removal marquez29 Carpentry 16 03-30-2009 12:34 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
