Pipe Freezing Kit - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-17-2014, 09:55 PM   #1
Rewards Points: 46
pipe freezing kit
Has anyone bought or used a disposable pipe freezing kit they can recommend?
havago is offline   Reply With Quote
Old 10-18-2014, 07:00 AM   #2
Retired Moderator
Rewards Points: 7,174
What are you trying to do? I've never used a pipe freezer--but I have used a 'Jet Swet' tool with good results.
That tool slips inside of the pipe--a turn of the handle and an expansion plug stops the flow---a full port shut off valve can then be soldered on--and the tool removed.
Crushed Water Main--Happy Accident - General Discussion - Contractor Talk
Old 10-18-2014, 12:32 PM   #3
Rewards Points: 46
I need to install a tee for an outside tap and my incoming main stop tap is seized up. If I can freeze the pipe below the incoming main I can replace the stop tap and install the tee at the same time. The city want $160 to turn my supply off from the road.
Old 10-18-2014, 06:03 PM   #4
Retired Moderator
Someone here should have experience with one of those-----
Old 10-18-2014, 06:10 PM   #5
Rewards Points: 46
I used a disposable Arctic Spray kit when I was in the UK which worked great but haven't seen them this side of the pond.
Old 11-14-2014, 01:29 AM   #6
Rewards Points: 4,212
Is this in an area where a little water wouldn't hurt anything.?
ron45 is offline   Reply With Quote
Old 11-15-2014, 09:15 AM   #7
Rewards Points: 46
It would have flooded my finished basement. I found an Arctic Spray disposable kit online at home depot, worked great, job done. Since then I found that noble stock the full range of kits and Wolseley and Emco can order in but didn't have them in stock.
Old 11-16-2014, 12:48 PM   #8
I had a similar problem in a rental and it was the weekend. Not a finished basement.
My solution to the problem, not as cool as yours.
I took a good shut off valve and attached it to a shark bite with valve in the open position.
Cut the pipe and shoved the shark bite on, then closed the valve.
The Following User Says Thank You to ron45 For This Useful Post:
oh'mike (11-17-2014)
Old 11-16-2014, 03:39 PM   #9
Rewards Points: 46
I see the relevance of your first question now. Shark bite are good and they have shark bite shut off valves now too. I've done the same myself.
Condenser Pipe Close to freezing, is this an issue? knotquiteawake HVAC 5 08-13-2012 04:58 PM
Pipe freezing mitch08 HVAC 9 05-29-2012 11:14 AM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 04:01 PM
sewer pipe smell when weather is below freezing ltj Plumbing 4 12-17-2009 02:24 AM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
