Painting Bead Board - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-12-2016, 02:24 PM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 238
Painting bead board
Bought 3/8 wooden bead board to put up on my walls. When I applied prime to my first board,it dried with all this "furry" type layer, so I lightly sanded the next board with 220 grit, and tack clothed it, put it did not seem it smooth out the surface.
What should I be doing???
Thanks, Barry
Barry J is offline   Reply With Quote
Old 04-12-2016, 03:44 PM   #2
Rewards Points: 144
Re: Painting bead board
You say "wooden bead board". Can you be more specific? Sheets?What kind of primer?
In general I would suggest to apply some Zinsser primer,then sand lightly and then paint.
You're probably using a waterbased primer without a lot of solids and it's raising the grain.That's ok .Just lightly sand.
mako1 is offline   Reply With Quote
Old 04-12-2016, 06:11 PM   #3
Rewards Points: 2,490
The boards should be sanded first. Wipe with wet rag to raise the grain, let dry and sand. Apply 1:3 shellac-alcohol which will stabilize the surface more. Sand again then use the primer. I think your boards are too soft and the surface fibers are worn out or machined with dull knife at the factory. You locked in the rough texture with primer and it will need more sanding to smooth out.
I may return the boards and look for better quality material.
carpdad is offline   Reply With Quote
installing backer board over particle board bob mac Flooring 6 07-16-2013 03:15 PM
WAINSCOTTING With BEAD BOARD Nathan Carpentry 29 02-24-2013 03:42 PM
Painting old interior barn board lklatt Painting 0 10-02-2010 07:59 PM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 10:03 AM
Painting Rooms with Round Corner Bead leafyme Painting 9 08-20-2008 02:52 PM
