Outdated Opening. - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-28-2014, 01:49 PM   #1
Rewards Points: 764
Outdated opening.
I'm helping someone house hunt. This is one possibility but what can be done with this opening in the wall that has outdated spindels?
I suggested closing it up completely with drywall, but the house hunter likes the open look.
Maybe a wide ledge for a passthru, but that seems silly as its next to the kitchen doorway.
Would a different shape spindle improve the look?
This doorway doesn't even have any framing? Is that cheap looking?
Or, removing the entire wall if possible.
Startingover is offline   Reply With Quote
Old 11-28-2014, 03:30 PM   #2
Doc Sheldon's Avatar
Rewards Points: 400
How about a bar nook? Is there adequate space on the kitchen side for stools?
Doc Sheldon is offline   Reply With Quote
The Following User Says Thank You to Doc Sheldon For This Useful Post:
Startingover (11-28-2014)
Old 11-28-2014, 03:38 PM   #3
Rewards Points: 764
Thanks for the idea. We haven't been inside yet. We're trying to consider all options before we bother a realtor.
This is the 2nd house being considered. Kitchen looks better BUT, who would recess a stove like this? If you know anything about cooking you are constantly taking lids off pans or putting them on. You need a spot close by for potholders or spoons for stirring. Plus I keep trivets next to stove for sliding hot pans onto from the burners.
So I wondered about knocking down this brick work around the stove?
Old 11-28-2014, 03:52 PM   #4
Rewards Points: 400
Another idea might be to replace the spindles with shelving... could be open to both sides, closed on the kitchen side, one-way glass on the kitchen side...
Old 11-28-2014, 03:53 PM   #5
Rewards Points: 400
Or a live lobster tank... Visitors can pick out their dinner and the cook can... what? Been done? Never mind!
Old 11-28-2014, 07:10 PM   #6
Retired Moderator
Rewards Points: 7,174
That brick work should not be to difficult to remove---it might be holding up the arch--so that might need support or removal--
Changing Window Size TinaV Remodeling 3 11-06-2012 12:30 PM
creating an opening bearing or not? Wiscbldr Building & Construction 2 11-01-2010 02:32 PM
Putting a wall over a large opening, need ideas aqzman Building & Construction 5 10-28-2009 03:46 PM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
Finishing opening for closet Frank_N_Stein Carpentry 11 12-24-2008 08:52 PM
