Is Our Kitchen Gas Line Okay Just Lying On The Floor? - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Nealtw
  • 1 Post By MI-Roger
Old 12-18-2017, 02:14 PM   #1
Rewards Points: 26
Is our kitchen gas line okay just lying on the floor?
Our kitchen is being remodeled. The new cook-top is going to be on a different a wall than the old one, so they are re-routing the gas line from the old location to the new one.
Our contractor has placed the gas line on the floor. This will be behind the base cabinets once they are installed. Please see the picture.
Is this the right way to do this?
SM_Jeff is offline   Reply With Quote
Old 12-18-2017, 02:19 PM   #2
retired framer
Rewards Points: 18,784
Re: Is our kitchen gas line okay just lying on the floor?
If it will be hidden with cupboards, I would think it will be fine as well as the easiest and cheapest place to put it.
chandler48 likes this.
Old 12-18-2017, 06:46 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 748
Jeff,
I am not sure since I'm a tileguy, but........common sense tells me this may not pass inspection if there's any joints that will be hidden and not accessible. I also would not be happy with them notching my new cabinet frames in order to do it this way. Looks like you have a crawl or basement under there. So why not go that way?
Without searching codes books, I would ask what your town's inspector has to say.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 12-18-2017, 06:56 PM   #4
Guapo
Rewards Points: 11,950
Maybe it doesn't show in the pic but I don't see any unions in the pipe. It looks like one long piece.
Guap0_ is offline   Reply With Quote
Old 12-19-2017, 02:13 AM   #5
Tileguy
JazMan's Avatar
Rewards Points: 748
Guap0,
You don't think the ends where the joints are will be exposed, do you?
Jaz
Old 12-19-2017, 02:55 AM   #6
retired framer
I don't see a problem with hiding a black pipe in the kick area under the cupboards.
Old 12-19-2017, 05:29 AM   #7
Licensed Engineer
Rewards Points: 467
It looks half-assed to me but I don't know your local codes. Regardless, even if it meets code it should have a couple of intermediate anchors to secure it in place.
MTN REMODEL LLC likes this.
MI-Roger is offline   Reply With Quote
Old 12-19-2017, 10:18 AM   #8
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,054
Plenty of IP gas pipe joints are hidden in walls and everywhere..... Unions can not be hidden and must be accesable.
They must be secured though.... don't recall the actual code.
MTN REMODEL LLC is offline   Reply With Quote
Old 12-19-2017, 11:40 PM   #9
Rewards Points: 870
3/4" or 1" pipe is to be supported every 10 ft. as per Oregon Mechanical Code C416. Or whatever code is adopted and enforced in your area.
If NFPA 58 is enforced in your area, use that.
fireguy is offline   Reply With Quote
The Following User Says Thank You to fireguy For This Useful Post:
MTN REMODEL LLC (12-20-2017)
Running new kitchen drain because 1953 wasn't friendly with connection height scgt1 Plumbing 16 02-03-2017 11:57 AM
Kitchen Tile on Uneven Floor & Floor Heating badsha Flooring 59 02-25-2014 09:37 PM
Engineered hardwood over vinyl tile - am I being unreasonable or am I getting screwed photopeter Flooring 25 02-01-2014 11:41 AM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
