Oscillating Saw ?? - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-23-2015, 04:28 PM   #1
NorPlan's Avatar
Rewards Points: 256
Oscillating Saw ??
We've Removed a Stove Top / Counter Top Incert.. The idea is to fill in the hole if you will with a piece of 1 1/2" Bambo Counter Top.. Without Removing / Undoing the Counter Top we want to cut straight back from the Outside edge to the Wall.. The last couple inches , would an Oscillating Saw do the job without cutting into the Wall ??
NorPlan is offline   Reply With Quote
Old 12-23-2015, 04:50 PM   #2
Rewards Points: 144
Any oscillating saw is not a tool for finish work and you will not be pleased with the results.
mako1 is offline   Reply With Quote
Old 12-23-2015, 06:52 PM   #3
Retired Moderator
Rewards Points: 7,174
That is the tool that I would use----I think you will be able to get the job done nicely.
Old 12-23-2015, 06:54 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 9,252
I agree....the key is using the right blade and being careful.
In God we trust, for everything else....use a Sawzall....
ddawg16 is online now   Reply With Quote
Old 12-23-2015, 07:00 PM   #5
NorPlan's Avatar
Rewards Points: 256
That's my Canundrum, to do this without leaving a mark on the wall.. Have made some Ambedextrus Cuts in the past with the Sawzall..lol...
Old 12-23-2015, 09:12 PM   #6
firehawkmph's Avatar
Rewards Points: 2,452
I have a Fein Tool. It will leave a very nice cut if you have a steady hand and know how to use the tool. Practice on some scrap first if you can. You could also put a piece of thin sheet metal like coil stock flat up against the wall where you are going to finish your cut. That way if you slip and touch the wall, it won't hurt anything. Get a good blade. I like Imperial brand with the titanium edge. They are made in the US and are better than the Fein blades. They make blades to fit all the oscillating tools.
Mike Hawkins
firehawkmph is online now   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
NorPlan (12-23-2015)
Old 01-05-2016, 09:40 AM   #7
NorPlan's Avatar
Rewards Points: 256
Well job is complete , unscrewed Counter Top from Cupboard Frame and raised it an inch to give me some cutting clearance...lol.. Used a Circular Saw and Chop Saw , the later successfully without nicking the Back Splash which was my main concern.. Used a piece of Bambo from another job.. Was told a Circular Saw wouldn't cut but it was like soft butter on bread..lol..
If I had the Techno Where With All to Post a Picture of the Finished Job I'd gladly do so..
Can a flush cut (oscillating tool) saw cut cinder block? KarlJay Concrete, Stone & Masonry 7 08-01-2015 06:40 PM
Oscillating tool poll gmhammes Tools 28 08-20-2011 11:18 AM
Oscillating Multi-Tool For Gutter/Downspout Work? More Power! Tools 23 08-07-2011 06:05 PM
Oscillating tool adapter retired guy 60 Tools 1 03-12-2011 11:19 PM
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 02:24 AM
