Options To Remodel My Shower Stalls - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-09-2019, 07:45 PM   #1
Rewards Points: 2
Options to Remodel My Shower Stalls
I bought a campground that has four fiberglass shower stalls in the restrooms. Two stalls look like the picture and the other two are ADA Showers that have no lip at the bottom to keep the water inside.
The curtains keep falling out of the showers and allow the water on to the floor. Sometimes the water in front of all the shower stalls is an inch deep.
I am looking at a couple options:
1. Remove the shower stalls, cut out the concrete four feet outward from the original drain and slope it towards the drain. Then line the floors and walls with a material I could spray down everyday when cleaning. Basically the the shower area would now be 1 1/2 times bigger.
2. Leave the shower stalls in place and just cut out the concrete in front of the stalls about a foot, install another drain and slope concrete towards the new drain. The stalls are starting to show their age.
Any suggestions? Cost is a major factor, but also longevity and ease of cleaning
Thank you
Greg
moose107 is offline   Reply With Quote
Old 08-09-2019, 07:56 PM   #2
retired framer
Rewards Points: 18,608
Re: Options to Remodel My Shower Stalls
Learn how to work with fibreglass or hire some one who does that work and just raise the bulkhead.
Do not use flat bottom gables with scissor trusses.
Old 08-09-2019, 08:25 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,624
Maybe installing ADA compliant roll over thresholds in the handicapped ones along with longer shower curtains would help. https://www.amazon.com/ADA-Wheelchai.../dp/B01LWPMOZ8
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 08-09-2019, 08:31 PM   #4
Rewards Points: 3,944
Btw, you can just throw that shower curtain in the washer with detergent & bleach & it should come clean.
Nik333 is online now   Reply With Quote
