Opening Up Basement Stairs - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 12-02-2018, 01:33 PM   #1
Rewards Points: 42
I am in the planning phase of finishing my basement and would like to open things up and add a bannister for the bottom 5 steps. Looking for input on how I can accomplish this, as I assume I cannot just cut the wall back. Thanks!
Opening Up Basement Stairs-img-1033.jpg   Opening Up Basement Stairs-img-1034.jpg   Opening Up Basement Stairs-img-1035.jpg   Opening Up Basement Stairs-img-1038.jpg   Opening Up Basement Stairs-img-1039.jpg
slowmotion is offline   Reply With Quote
Old 12-02-2018, 03:05 PM   #2
retired framer
Rewards Points: 18,584
Re: Opening Up Basement Stairs
The 2x4s along side of the stringers might be doing all the work but you can cut above that no problem.
Old 12-02-2018, 05:36 PM   #3
Rewards Points: 42
If I remove the 2x4s highlighted in red in these pictures, how will the joists be supported? My guess was that I would still need a posts on each side at the bottom of the stairs.
Opening Up Basement Stairs-img-1044-copy.jpg   Opening Up Basement Stairs-img-1045-copy.jpg
Old 12-02-2018, 05:49 PM   #4
retired framer
Sorry I missed that.
You will want 2 or 3 studs in the that corner The other two are fine on hangers we can see the hanger on the right one. You can add a hanger to the left one, but you are stuck with the center one.
Unless you want to run a beam somewhere to support it.
Old 12-02-2018, 06:10 PM   #5
retired framer
slowmotion likes this.
Old 12-02-2018, 06:20 PM   #6
Rewards Points: 42
Thanks Neal. How do you treat the double top plate?
Old 12-02-2018, 06:47 PM   #7
retired framer
I would work on the two corner posts first. just hammer a stud under the joist a little tight so it take the weight off the corner, put a block of wood under the stud to spread the load on the floor.
Then remove all the studs and top plates at that corner and install a post in its place with something between the post and floor plastic or tar paper, what have you. Then move you stud over to the right and remove the rest of the top plate install the hanger. Then do the same on the other side.
You will want at least one bracket on each post.
I would build the posts out of 3 2x6, crowned in opposite directions pulled straight with corner nails. 2 or 3 nails top and bottom nice and flush then in the middle use nails from the corner on an angle, will pull them flush and then finish nailing them.
The Following User Says Thank You to Nealtw For This Useful Post:
slowmotion (12-02-2018)
Old 12-02-2018, 06:56 PM   #8
retired framer
@slowmotion BTW use real hanger nails. 1 1/2" they are the same fat as a 3" nail. You can use them to pin the bracket to the floor too, drill 3/16" hole in floor put a piece of garden trimmer string or wire in the hole and drive the nail.
Help with Basement Stairs audis$ Building & Construction 6 12-06-2013 03:52 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Changing Window Size TinaV Remodeling 3 11-06-2012 12:30 PM
Repairing basement stair opening (and stairs) ScrewLooseDan Building & Construction 5 05-27-2011 10:25 PM
water comes down basement walkout stairs carriepartlan Building & Construction 1 07-09-2009 06:13 PM
