Opening An Enclosed Porch - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-09-2015, 11:21 AM   #1
Rewards Points: 4
Opening an enclosed porch
We bought a house that was initially built as a one story on stilts. At some point they enclosed the bottom making it a two story. They had the bottom porch enclosed at a later time (not done very well rendering the space useless) and we want to open it back up. The problem is that toward one end one of the existing pillars for the upper floor is exposed a few feet back from the edge of the slab and can not be moved. We are afraid that putting the new pillars that far back will not adequately support the roof. So my question is how far can we go back before it compromises the support? What is the maximum overhang length for porches? Also any ideas on a better solution would be greatly appreciated. Note that the roof is not a large slant. Thanks, Misty
mistimnoah is offline   Reply With Quote
Old 09-12-2015, 09:08 AM   #2
Rewards Points: 4,212
You would get better advice and more responses if you post some pictures.?
Is this water front property.?
ron45 is offline   Reply With Quote
The Following User Says Thank You to ron45 For This Useful Post:
Ron6519 (09-12-2015)
Old 09-12-2015, 02:27 PM   #3
Rewards Points: 144
"toward one end one of the existing pillars for the upper floor is exposed a few feet back from the edge of the slab and can not be moved"
And try previewing your post before hitting the post button.If you were reading this and someone else posted it would you have a clue?
mako1 is offline   Reply With Quote
Tags
enclosed porch , overhangs , pillar , porch remodel , supports
Open porch built over basement and garage- porch rot JohnMargaret Building & Construction 8 06-06-2016 09:33 PM
loads for 2 story covered porch deatra1994 Building & Construction 3 04-10-2014 10:24 AM
Pre-planning: converting front room back to porch WillK Building & Construction 3 11-06-2011 12:47 PM
Old roof opening mystery Mike in Arkansas Roofing/Siding 10 03-23-2010 06:19 AM
Enclosed Porch Roof - Sheathing LowVolts Roofing/Siding 7 08-01-2009 08:34 AM
