Which One First - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By BrownEyedGuy
Old 10-03-2018, 01:40 PM   #1
cia2a's Avatar
Rewards Points: 30
Which one first
I have a Kerdi shower pan ready to install, I have my hardiboard up on the walls.
Should I install the shower pan and floor before I tile the walls or after.
cia2a is offline   Reply With Quote
Old 10-03-2018, 04:21 PM   #2
JUSTA MEMBER
Rewards Points: 3,672
Re: Which one first
Before, that way the tiles can cover the leading edge of the pan, and provide a way to drain the water off the wall into the pan.
ED
de-nagorg is online now   Reply With Quote
Old 10-03-2018, 04:25 PM   #3
Rewards Points: 1,314
Re: Which one first
In all things water related, you always install from the bottom up...at least from the perspective of overlapping components. You always overlap from above to prevent water penetration as it runs down a surface.
de-nagorg likes this.
BrownEyedGuy is offline   Reply With Quote
Old 10-03-2018, 09:24 PM   #4
cia2a's Avatar
Rewards Points: 30
Re: Which one first
Thanks everyone, I appreciate this.
4 wire HVR lrkc HVAC 10 10-18-2015 03:05 AM
Thermostat - Nest install VincentS123 HVAC 42 09-26-2015 07:43 AM
Priority Project - The Bathroom Eutopia Building & Construction 6 10-12-2011 12:19 AM
Advice on priority of repairs: gutters and basement nshroyer Building & Construction 10 07-06-2011 08:40 PM
Wiring a Priority valve for a water heater Frankn63 Plumbing 0 07-28-2010 02:01 PM
