Old Walls - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-13-2012, 07:37 AM   #1
Question
Old Walls
Hi!
I live in an older house. I need to replace what I thought was just drywall under my bedroom window. When I tore out the damaged section, it looks like there is a sheet of drywall behind a sheet of cement board. I am a DIY novice, so I have stopped my project until I have a better understanding of what I need to do. Does this sound familiar to anyone? I now am wondering if I need to install some sort of backer board then drywall, or just install a 3/4 inch sheet of drywall. Any info would be greatly appreciated. Thanks and Have A Great Day!
babyblue is offline   Reply With Quote
Old 08-13-2012, 12:43 PM   #2
Rewards Points: 17,912
Unless this is a tiled wall there's no need for cement board.
If I had to guess I'd say that window has been leaking for a while and it's been repaired before.
If the other walls are plaster and lath they may have used the drywall as a shim to get the wall to come out even.
There is no 3/4 drywall that I've ever seen. May just have to shim out the studs and use 1/2" drywall.
It would be great if you could post a picture.
I'd be checking why that widows leaking, cheaking all over behind the walls for wood rot, fixing all that before messing with the drywall.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 09:20 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 01:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 04:12 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
