Old Tub With No Lip Around The Edge - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-27-2015, 07:34 PM   #1
Lord of Slums
Rewards Points: 1,974
old tub with no lip around the edge
I am repairing a long term water leak no body told me about. The tub is probably from 1920, and has no lip around the edge. I do not want to bring the fiberglass enclosure down to the tub and caulk because water will get in. Do i need to tear out the tub?
mj12 is offline   Reply With Quote
Old 09-27-2015, 08:14 PM   #2
griz's Avatar
Rewards Points: 572
Yes, tear it out.
griz is offline   Reply With Quote
Old 09-27-2015, 09:34 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 748
Replacing the tub might be in order, but I think we need more info and perhaps some pics to confirm. I'd wanna make sure there's no simply fix before ripping out a tub that is 90 years old. You're liable to get into a lot more work than planned.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 10-04-2015, 12:23 AM   #4
Rewards Points: 2,458
If the sheathing on the wall is not touching the tub, there's no reason to replace the tub thinking the flange is absolute.
If replacing the sheathing, use cement/composite board and stay 1/4" off the tub. Make sure the tub is clean. Tape off and fill 1/4" with OSI quad. You will need ventilation for about 1/2 a day for the smell from this caulk. Tape off at least 3" on wall and tub so you can really press the caulk in without having to worry about the squeeze out. You may have to pre-install blocking, tape, can foam-whatever, so the caulk doesn't just fall through. There are other caulks, but OSI is one I used and observed for adhesion. You want to smear/press the caulk on the surfaces so that it has adhesion.
carpdad is offline   Reply With Quote
Roof drip edge after re-siding job MI-Roger Roofing/Siding 9 02-05-2016 05:58 PM
Drip Edge on the Rake mjb_2 Roofing/Siding 13 02-15-2015 02:41 AM
Securing fascia under the drip edge? miamicuse Roofing/Siding 6 07-23-2014 10:33 PM
Ice and Water Shield under drip edge? sutterml Roofing/Siding 10 07-11-2011 05:04 AM
roof drip edge billygale Roofing/Siding 9 10-24-2010 02:19 PM
