Notched Studs - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 05-02-2019, 06:45 PM   #16
Rewards Points: 6
Nealtw
Don't see any bolts here. Just concrete slab under, couple nails.
Mystriss
This wall is perpendicular to an exterior wall which I know is load bearing. Thanks for that link and info very useful. I've got about 80% notched out for 3 studs in a row, none are doubled.
HenryMac
I have both cabinets at the base and one at height. The one at height is installed at a corner, so it's connected to this wall and another wall for the pantry. Hopefully this sounds like it could reduce any bend issues.
Sounds like at minimum I need stud shoes and some extra reinforcement. Not sure how I can reinforce correctly- there's only space between the studs. Sounds like I also need to call the plumbing company to have a conversation.
Bowler is offline   Reply With Quote
Old 05-02-2019, 06:50 PM   #17
retired framer
Rewards Points: 18,706
Re: Notched studs
Originally Posted by Bowler View Post
Nealtw
And do the joist land above the wall.
I don't think you will find a shoe for a cut out that big, that will add to the anti bend strength.
Do not use flat bottom gables with scissor trusses.
Old 05-02-2019, 07:08 PM   #18
HenryMac's Avatar
Rewards Points: 998
Re: Notched studs
A) Can you post up a photo of the cabinets on the other side?
B) Is the work that was done something that needs a permit pulled for the work?
Regardless as to if it will work as-is, it needs to be done to code. Using the cabinets on the other side for supporting shoddy work is a band aid.
What size is the pipe o.d.? Looks to me, to to meet code, even a 2x8 wall wouldn't work.
HenryMac is offline   Reply With Quote
Old 05-04-2019, 06:49 PM   #19
Rewards Points: 6
Doesn't appear that the joists land on the wall.
Here's a photo of the other side of the wall
https://imgur.com/a/6M9g9DG
No permit was necessary to my knowledge
Old 05-04-2019, 06:50 PM   #20
Rewards Points: 6
The pipe is 2.5" wide. Looks like a standard PVC drain pipe to me
Old 05-04-2019, 06:53 PM   #21
retired framer
Re: Notched studs
Which direction do the joists go?
Old 05-04-2019, 06:58 PM   #22
HenryMac's Avatar
Rewards Points: 998
Re: Notched studs
Thanks, that helps a bunch. I wouldn't be worried at all about the weight on the wall from the cabinets since there is a panel that goes all the way to the floor.
Is that a vaulted ceiling? Does it land on this wall?
So it's likely 2" pipe, which is 2-3/8" O.D. (2.375).
Even with a 2x6 wall, anything over 2.2" o.d. isn't really code legal.
Old 05-04-2019, 06:59 PM   #23
retired framer
Re: Notched studs
I really don't think it matters if it is bearing or not, that wall needs help, more structure.
Best Practice: Holes in studs, top/bottom plates, & floor/ceilling joists? Mystriss Building & Construction 15 02-18-2019 11:34 AM
Plumber Notched Load Bearing Wall fixit26 Building & Construction 15 01-22-2018 01:24 PM
Old wall and new studs are different dimensions. Photobug Carpentry 13 11-15-2017 06:23 PM
The stringer on my stairs is pulling away from the wall/ studs. georgiabiker Carpentry 10 01-24-2013 03:53 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 04:16 PM
