Notch In Joist - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-09-2014, 11:12 PM   #1
Rewards Points: 4
Notch in joist
Plumber notched a joist between first and second floor. I want to get it fixed right but having read articles here about sistering in another full length joust, it doesn't seem possible. The notch is close to the outside wall. What type of repair would be structurally sound?
Fletcharr is offline   Reply With Quote
Old 11-10-2014, 03:03 AM   #2
Rewards Points: 4,134
Are you sure a plumber did that.?
ron45 is offline   Reply With Quote
Old 11-10-2014, 06:16 AM   #3
Rewards Points: 4
Notch in floor joist
Yes. I am a woman and know nothing about construction or should say knew very little. I know more now after this remodeling. This plumber is a big guy and when I tried to tactfully suggest that was a rather big hole in my joist, he literally puffed out his chest, stepped into me as if to back me down and said "lady I needed room to work." He acted like it was fine and I was out of line to ask. I moved away for a year and the project sat so recently I started up again and brought in a highly recommended plumber to look at the work. He told me you never notch the bottom of a joist. Sadly my contractor put decorative beams under as part of kitchen remodel so it will be hard to sister something in the new plumber pointed out that this same guy cut out my air vent, left the home in the roof and put in some temporary vent the stops at the bottom of the window. It is frustrating as I using one if the best contractors in my area, but I think the sad reality is that because it is a lower end project it doesn't get the attention a million dollar project does. However I work as hard for my
Money as any millionaire and want it done to code. I don't want to play the gender card, but I think this might not be happening if they had to face a man.
Old 11-14-2014, 12:45 AM   #4
That is a mess, I hope your new plumber can straighten it out.
Old 11-14-2014, 04:46 AM   #5
Rewards Points: 2,528
Your highly recommended plumber is incorrect. Joists can be notched but certain criteria must be met as applied to the actual dimensions of the lumber.
-Do not make notches in the middle third of the span
-The maximum notch depth is not to exceed 1/6 the depth of the joist
-The maximum notch length is not to exceed 1/3 the depth of the joist
So if your joists are 2x10's and are 12 foot long:
-No notches between 4 and 8 feet of the span
-Max notch depth can be 1-1/2 inches
-Max notch length can be 3-1/16 inches
hammerlane is offline   Reply With Quote
Old 11-14-2014, 02:40 PM   #6
Rewards Points: 7,160
Thanks for the specs hammer. He clearly broke rules 2 and 3, but if that is a supporting wall we are looking at, its so close to the support, that a lot of people would not worry about it. (except of course your plumbing looks like it was done by anything but a plumber)
SPS-1 is online now   Reply With Quote
Old 11-16-2014, 06:57 PM   #7
Davejss's Avatar
Rewards Points: 894
Hey! Actual, accurate code advise on a DYI forum! That's something you don't see every day!
I'm done with my plumbing an electrical subs hacking away at structure, and I don't allow it. If they break it they fix it or they don't get paid. Period.
Davejss is offline   Reply With Quote
Old 11-17-2014, 06:48 PM   #8
Rewards Points: 454
As far as structurally it would be fine cause there's enough stud left, I would be more worried about running a screw thru one of the pipes especially after its covered with drywall like when you Mount the cabinet and such. plus I would be worried about a leak, in the future if there isn't pride in the work that shows think about what you can't see
scottktmrider is offline   Reply With Quote
Old 11-17-2014, 10:36 PM   #9
There is different notching and boring criteria for studs. The poster is referring to a joist.
Old 11-18-2014, 06:40 PM   #10
Rewards Points: 454
My bad, I thought it was a wall stud not a floor joist
I have to notch a floor joist fred54 Building & Construction 32 01-15-2014 07:52 AM
Sister Joist - Notch Question pleasedrivefast Building & Construction 8 06-01-2012 07:50 AM
Floor Joist Notch trophywalleye Building & Construction 1 02-03-2011 03:49 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Fix illegal notch in joist acerunner Carpentry 8 09-29-2010 06:01 PM
