No Moulding Under Window Sill? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-18-2017, 06:07 PM   #1
Rewards Points: 314
no moulding under window sill?
My tile guy told me that I should not put any moulding under my window sill in my bathroom because the decorative tile listello runs right underneath it. Is he right? It just seems like it's lacking something. The sill just seems to be too thin.
njitgrad is offline   Reply With Quote
Old 05-18-2017, 06:10 PM   #2
Rewards Points: 17,884
Re: no moulding under window sill?
That's called an apron, and it's not need when you had the tile installed.
Looks good to me.
Old 05-18-2017, 06:52 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
its fine. and much easier for the tile installer to just go right up to the window sil. its done all the time in bathrooms and in kitchens with tile backsplashes
woodworkbykirk is offline   Reply With Quote
Old 05-18-2017, 07:13 PM   #4
Rewards Points: 898
I like it.
BIG Johnson is offline   Reply With Quote
Old 05-18-2017, 07:16 PM   #5
Rewards Points: 314
I guess it will just take some getting used to.
Old 05-18-2017, 07:52 PM   #6
Rewards Points: 314
How about replacing the sill with a thicker one to (somewhat) account for the missing apron?
Old 05-18-2017, 08:53 PM   #7
kwikfishron's Avatar
Rewards Points: 272
It's your house so you certainly don't have to "get use to it". If you want a piece of trim there then do it. You can glue up a piece right to the tile.
kwikfishron is online now   Reply With Quote
Leaky Window Sill CosmicMiami Building & Construction 3 04-27-2014 08:22 AM
solution for old wooden window sill hohadcr Windows and Doors 11 06-02-2012 02:29 PM
Window shrink film around sill? Liv2123 General DIY Discussions 4 01-31-2011 08:10 PM
my fix for rotting outside sill on wooden window guest General DIY Discussions 6 11-06-2010 02:58 PM
