New Stairs And Wood Flooring - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-07-2014, 11:24 AM   #1
new stairs and wood flooring
Im having my stairs redone. They are using 3/4" maple for the treads. I am also having carpet replaced with wood flooring upstairs. My flooring to be installed is 1/2" What is the right way to make up the difference at the landing between the wood on the stairs and the wood flooring? I believe it should be a flush transition (no moulding or transition strip) right ?
Toni Prunty is offline   Reply With Quote
Old 04-07-2014, 12:59 PM   #2
Rewards Points: 17,890
Sure it's not 5/4 (1" treads) not 3/4?
At the top of the stairs you should be using a landing tread.
Adding plywood to add the needed thickness to the whole subfloor for a level transition would be the way I would do it.
Wood over Concrete Stairs? Need Some Knowledge From You Guys jousley Building & Construction 26 06-27-2012 09:38 AM
Flooring on stairs opinions wanted! Waterfroggy Flooring 2 05-17-2012 05:35 PM
install wood flooring on stairs cfoush Flooring 4 08-18-2011 11:37 AM
Wood flooring and Stairs dsickler Flooring 6 04-14-2011 11:51 AM
Engineered or Solid Wood flooring on stairs VickyC Flooring 1 03-05-2010 06:50 PM
