New Header - Hate It, Want To Recess It - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-30-2016, 12:45 PM   #1
Rewards Points: 14
New header - hate it, want to recess it
So I just installed a 2- 2x12 x 10' header and I hate it, it divides the room too much for my liking. I'm a home DIYer and had a draftsman do the drawing and then I had them approved at the local county office.
I want to hide 8" by recessing it, can I use 2x8 joist hangers on the same header or does it have to be engineered lumber or more plys etc??
I'm out of Fairfax VA if that helps.
brady5885 is offline   Reply With Quote
Old 01-30-2016, 01:40 PM   #2
Rewards Points: 17,912
An engineer would be need with stamp drawings for a redesign like that and require major reconstrution.
Big difference from a header to a let in main beam.
Pictures would sure help when making guesses.
Old 01-30-2016, 02:39 PM   #3
Rewards Points: 14
We had drawings stamped and approved.
It wouldn't take major reconstruction, it would mean me cutting the joists and moving the header up and put it on taller posts.
I installed it and took it out again.
For some reason my phone says error when resizing image
Old 01-30-2016, 02:58 PM   #4
WhatRnsdownhill's Avatar
Rewards Points: 2,220
are the ceiling joists already split ontop of that header? not one continous beam from one side to the other?
WhatRnsdownhill is offline   Reply With Quote
Old 01-30-2016, 03:13 PM   #5
Rewards Points: 14
Correct, yes.
Old 01-30-2016, 03:18 PM   #6
What your suggesting doing effects the whole structure of the home.
The top loading goes all the way down through the floor to whatever is below it down to the ground and most often must be on proper footings.
Ceiling would need temperary supports on both sides.
I'd be surprized if the building department allowed you to just add spacers and not make you use redo with all new stacked 2X's.
Old 01-30-2016, 03:19 PM   #7
Rewards Points: 6,140
The ceiling joists not only hold the ceiling up, they often hold the walls together to oppose the weight of the roof and any load it is designed to carry. Snow load is common, but I don't know your location.
As an option, if the space above is just empty attic, in some cases the header can be installed above the joists, allowing them to remain connected covering the span to hold the walls together.
In addition to installing your new beam, you need to be sure that load is supported on each end ant the total weight is transferred to proper supports below. Thus the need for an engineer to work out the details.
Bud
Bud9051 is online now   Reply With Quote
The Following 2 Users Say Thank You to Bud9051 For This Useful Post:
joecaption (01-30-2016), oh'mike (01-30-2016)
Old 01-30-2016, 03:28 PM   #8
Rewards Points: 14
Ok, I had drawings made, approved and I installed as per drawings.
I have new footings for the posts, 4x4s etc.
All I'm wanting to do is to move the header up 8" so it's recessed and use hangers.
I'm not saying I want a wall out can I put a header in lol
Old 01-30-2016, 05:10 PM   #9
Whole design has been changed so old drawings mean nothing.
Going to have to go back and get a whole new plan and permit.
4 X 4's for what?
4 X 4's are going to want to twist and curl.
Still have no pictures of anything so where all stuck having to guess what reality would dictate.
Old 01-30-2016, 05:57 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 738
Whoever engineered your drawings will have the answer. Have him make the corrections if needed and have it in hand for your inspector.
Old 01-30-2016, 07:35 PM   #11
Rewards Points: 14
4 X 4's for what?
He spec'd 4x4 for the upright supports for the header.
One is embedded in the wall (see to left of pic), the other goes from the header down into the basement approx. 16ft onto a new footing.
I have removed the header and 16ft column for now
Old 01-30-2016, 08:12 PM   #12
Super Moderator
joed's Avatar
Rewards Points: 23,800
2x12 are not going to be flush even when recessed. It is still going to stick down 4 inches.
Your engineer will be able size something 7.5" to sit flush with the existing 2x8s.
The Following User Says Thank You to joed For This Useful Post:
Old 01-30-2016, 08:33 PM   #13
Retired Moderator
Rewards Points: 7,174
If you really don't like the look---you have been given two very viable solutions--
A beam 7 1/2 " perhaps with a steel flitch plate--and a saddle beam--mounted above the cieling----
Your idea will also work---however, as long as you have an engineer on board, check with him--the hangers needed will be important,whatever remedy you select.
Old 01-30-2016, 08:46 PM   #14
you shouldnt have an issue, just run it past the engineer that did the original drawings to make sure, and it will be flush on the bottom for a smooth ceiling and the rest of the header will stick above the ceiling joists...Ive got 4 x 4s holding a deck up for 15 years and they are straight as the day I put them in..they wont twist or warp...
Old 01-30-2016, 08:57 PM   #15
Just to add, I see a stairwell to the right of this new wall, so those joists do not extend outside to outside and I would assume there is a full story above. If living space is above, then the saddle beam is out.
If you don't want to revisit the engineer, then you will need to get your local inspector to sign off. Somebody closer to the project than we are needs to assume the responsibility.
Bud
recess exterior header dep378 Building & Construction 14 08-17-2012 04:44 PM
Header question - raising door and window RO enoll Building & Construction 10 05-04-2012 04:39 PM
Garage Header rwbil Building & Construction 11 09-16-2010 11:50 AM
Raise header of house wall plus add more header capslock Building & Construction 22 02-01-2010 09:13 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 12:50 AM
