New Floors Out Of Plywood ??? - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-25-2014, 02:51 PM   #1
jjgrask's Avatar
Rewards Points: 2
New floors out of plywood ???
I have a 1984 mobile double wide home that is about 900 square feet. The house is pretty solid and well built. But I want wood floors and I am on a very limited budget. I read in a magazine about using 3/4 plywood cut into planks and laid as wood flooring the stained with poly over the top. I would like your advice on this. I figure for the kitchen, hall, bath, and living room it would cost around $400.00 or so. I like the old rustic farmhouse look.
jjgrask is offline   Reply With Quote
Old 11-25-2014, 07:14 PM   #2
Rewards Points: 4,134
Anything can work.
What it did it say about T&G ( tongue and grove) If not, your either going to use a lot of nails/putty or a lot of glue.?
Have a look here and check out there prices. Even their Bamboo flooring is selling for just $1.69 SF.. That works out to be about $54 for the same area as 1 sheet of plywood.
http://www.lumberliquidators.com/ll/...6C15C=25255580
http://www.lumberliquidators.com/ll/...Nov19_Laminate
No I don't own the company or work there.....
ron45 is online now   Reply With Quote
Old 11-25-2014, 07:55 PM   #3
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,122
Would that be A/C Pine? Birch veneer? Maybe Oak Veneer?
I figure for the kitchen, hall, bath, and living room...
For the Kitch & Bath I'd have to suggest something else as a finish surface.
It's hard to beat vinyl sheet for basic/cheap wet area floor.
Well, except for maybe a tinted epoxy.
http://www.diychatroom.com/f4/small-...stions-210043/
Old 11-25-2014, 08:09 PM   #4
jjgrask's Avatar
Rewards Points: 2
Originally Posted by ron45 View Post
Anything can work.
Thank you got the answer back. I have bamboo in the bath now and loved it until a pipe sprung a leak. Bubbled up the finish and looks ugly. Only 1/2 of the floor got wet and the swelling is buckling the other side. I want a very rustic floor look so nails won't be a problem showing. Probably use glue also. I like the yellow pine. I know I can sand and refinish the plywood if something happens. The bamboo now has to be pulled up and replaced.
Old 11-25-2014, 08:12 PM   #5
jjgrask's Avatar
Rewards Points: 2
It is just hubby and me do wet floors are not a problem. I appreciate the concern but I have my heart set on wood of some kind. But thank you anyway
Old 11-26-2014, 06:32 PM   #6
Some high schools have wood and auto shops, and they take on projects. They don't charge much and it gives the students experience. We had both in the high school I went to. It wouldn't hurt to see if they would rip the plywood and T&G it for you.
By the way, I like your bike, what year is it.
I have a 2007 Low Rider.
Old 11-26-2014, 07:08 PM   #7
jjgrask's Avatar
Rewards Points: 2
Home Depot said they will rip the boards for free. We have a truck to haul them and a barn to keep them in until we use them all. Just have to pry up the old laminate floors and start laying them. I was thinking of using a putty knife as a spacer between the boards. I have 1/2 inch plywood subfloor under lam tile. Hope it works.
It's a 2011 Ultra Classic and my baby. Hubby rides a 2006 Road King on it's 2nd motor. We may be old but love our life.
Old 11-26-2014, 08:47 PM   #8
Rewards Points: 164
I'm confused why you'd spend more on plywood, than just buying actual flooring.
ryan50hrl is offline   Reply With Quote
Old 11-26-2014, 08:59 PM   #9
jjgrask's Avatar
Rewards Points: 2
I am looking for a rustic vintage look for a farm house. Eventually the inside and out will look like a old farm house with barn wood siding with a tin roof and a large porch. I have started my gardens and looking into making everything we use. I have used slate and stone in the bathroom and kitchen. Handmade cabinets and open shelving. My sinks are galvanized tubs with working plumbing. My ideas are a bit strange. I admit it. No, I am not a prepper or anything. But I want to be able to use modern things but look like 100 years ago. I really wanted a log cabin with dirt floors like my great grandmother lived in but hubby shouted no.
Old 11-26-2014, 09:04 PM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 9,252
The big issue you will have is that without the T&G on the edges, it will not stay flat and level AND you edges will splinter.
Now....lets talk budget.
A good sheet of plywood is around $35-40.
A 4x8 sheet of plywood is 32 sq ft.
There are some pretty good deals out there on budget laminate flooring. I did my sons with some and the cost was around $0.89 sq foot. That works out to about $29 for the same area as a 4x8 sheet of plywood.
Now....one would assume you would want to do a floating floor so you would also need the underlayment. That is going to cost you about another $0.50-0.90 per sq ft. But, then again, you would also need something under the plywood.
And, with the plywood you would have the cost of the Poly, not to mention the cost of nails or glue....and don't forget the enormous labor.
At at the end of the day, plywood strips would look like crap compared to other options.
So.....total cost + labor....budget laminate wins hands down....and looks a whole lot better.
Old 11-26-2014, 09:04 PM   #11
Rewards Points: 164
So do utility grade oak or maple flooring....it's cheap, it's going to look like hardwood would have decades ago. Plywood isn't going to look like hardwood of old, or hold up. the problem with plywood is it's layers are very thin, and not particularly well glued today. The edges and corners will very quickly break down and splinter. You'd be much much better served by purchasing something like this....
http://www.lumberliquidators.com/ll/...a-WP8/10012596
Or
http://www.lumberliquidators.com/ll/...-OA2U/10008112
Or
http://www.lumberliquidators.com/ll/...-MA2U/10008939
Old 11-26-2014, 09:05 PM   #12
JOATMON
ddawg16's Avatar
Too many horror stories about lumber liquidators.
Old 11-26-2014, 09:06 PM   #13
Rewards Points: 164
The options I posted are solid 3/4 inch hardwood (or pine for that one).....and at 99 cents a square foot they're cheaper than plywood....also you mentioned earlier about refinishing if needed. You will not be able to refinish plywood floors as the top most layer (veneer) is very very thin...like 1/16th inch or less. the second you sand through that you're down to garbage wood full of holes and splinters.
Old 11-26-2014, 09:07 PM   #14
Rewards Points: 164
Would I put in lumber liquidators if I wanted top notch flooring....no....but for utility grade flooring that's a replacement for plywood floors....any day of the week!!
Old 11-27-2014, 01:34 AM   #15
Rewards Points: 72
Hello. I'm a fan of rustic/ vintage themed houses too. But I guess plywood won't be a good choice. I'd prefer vinyl or hardwood for floors & stairs since they're sturdy.
emmyshaw is offline   Reply With Quote
How to Recoat (Sandless Refinish) Hardwood Floors RhodesHardwood How To Guides 11 03-12-2014 11:42 PM
Laying hardwood floors over plywood and tile in a mobile home chrismarx Flooring 3 04-15-2012 04:55 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 05:08 PM
Resurfacing Wood floors roxksears Building & Construction 2 10-23-2009 08:50 AM
Im I Ready To Install Engineered Floors??? babybull Flooring 5 01-29-2008 08:10 PM
