Need Help With Maximum Span For Trellis Beam? - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-29-2018, 02:13 PM   #1
Rewards Points: 2
Need help with maximum span for trellis beam?
I am looking to build a freestanding trellis structure. Made with CMU block columns, and (2) main beams that span approx 24' between the columns. The ID between columns is 24' x 16'.
Live in CALIFORNIA where there is no snow load.
Expect that the Main beams will have (6) 6x8 cross members and ontop of these (6) crossmembers will be some 2x2 on 1' Centers.
I can not find a table for a size of beam to span 24'.
Have read articles about bracing the beam with 1/2" plate steel, but still looking for he right beam dimension. Anyone have a source for this calculation?
bradma is offline   Reply With Quote
Old 04-29-2018, 09:43 PM   #2
JUSTA MEMBER
Rewards Points: 3,638
Re: Need help with maximum span for trellis beam?
Your beams will most likely warp badly.
Unless you can find some beams that are 100+ years old from an old barn.
Engineered beams are much better at staying true, and not warping.
ED
de-nagorg is online now   Reply With Quote
L shaped porch framing onjtrainee Building & Construction 34 02-07-2015 07:10 PM
Beam span Musaw17 Building & Construction 6 04-21-2013 03:16 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Triple 2x10 beam has twisted WillK Carpentry 11 12-28-2011 11:50 AM
Pergola construction - beam span without sagging fahartle Building & Construction 9 07-25-2010 07:54 PM
