Need Help Identifing If My Closet Is A Load Bearing Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-12-2015, 11:39 AM   #1
Rewards Points: 14
Need help identifing if my closet is a load bearing wall
I plan is to remove a 1st floor closet wall to open up some space. I contacted some contracts before I started tearing down the inside wall of the closet and he said he was 100% sure that it was NOT a load bearing wall.
To my surprise when I tore down the drywall inside the closet I saw a header. I just want to make 100% sure that it is NOT a load bearing wall before I remove it. If it is a load bearing wall, my plan will be to move the header up and get a longer 2x6. So that I can at least move the walls out some.
pizza0ut is offline   Reply With Quote
Old 04-12-2015, 11:41 AM   #2
Rewards Points: 14
I apologize for the Crayola blueprint . The red wall is the wall in question.
Old 04-12-2015, 12:50 PM   #3
Rewards Points: 17,890
Having a header does not mean much.
Need to be looking above and below it in the attic and basement or crawl space.
Old 04-12-2015, 01:52 PM   #4
Retired Moderator
Rewards Points: 7,174
Yep--as Joe mentioned---you need to look at the load on top---is there an attic above?
Which way do the ceiling joists run?
Does that wall sit on top of the center beam of the house? bearing center wall below ?
Old 04-12-2015, 03:48 PM   #5
Rewards Points: 14
After some measuring, I determined that the wall I want to remove does NOT sit on any beam. The back of the closet is the wall that is sitting on an I-Beam in the basement.
I also just tore down the ceiling drywall and found out that the joists are running with the wall.
Old 04-12-2015, 04:01 PM   #6
Rewards Points: 14
Picture of top plate:
Old 04-12-2015, 05:38 PM   #7
Sure hope you live in an area where it never ever freezes with all those over head copper pipes.
Old 04-12-2015, 06:53 PM   #8
Rewards Points: 14
We live in southeast Michigan. Those pipes are between the 1st and 2nd floors and are routed within the internal walls. I've lived here for 10+ years with no issues what so ever.
Old 04-12-2015, 06:56 PM   #9
Rewards Points: 14
Above the closet is another closet perpendicular to it.
Old 04-12-2015, 07:06 PM   #10
Retired Moderator
Yep---that closet wall is not load bearing--take it down---
Load bearing joining at brick wall. Studs where? corypa Building & Construction 2 02-07-2015 07:16 AM
Load Bearing wall? ssgtjoenunez Building & Construction 12 03-01-2013 06:03 PM
Load bearing wall? renntecher Building & Construction 2 02-04-2013 01:35 AM
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 05:35 PM
Looking into removing a load bearing wall IRuehl Remodeling 5 07-02-2011 03:39 PM
