Need Help Extending HE Furnace Vent - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-03-2018, 08:54 AM   #1
Rewards Points: 2
Need help extending HE furnace vent
Hello. I just built a pool deck and am putting a hot tub on it. Of course with the height of it and where I can put hot tub I will be right at the current vent for my furnace. Hot tub will be within a few inches of the vent, and in winter snow will now be on deck and hot tub which will block it as well. No good. Need to move the vent. I was wondering if I can take vent cover off, and some long sweep 90ís and 5 ft of 2 inch pipe, another 90 and put cover back on. I plan to strap pipe to house and paint to match siding color. My manual says Iím allowed up to 65ft for pipes. Right now just sections of pipe total 13ft from wall to furnace, I did round upo the nearest ft when measuring sections between fittings. Exhaust has 1 90 elbow and 3 45ís, intake has 5 45ís and 2 90ís and 1 long sweep 90. So if Iím right my exhausts is at 30.5 ft and intake is at 37.5ft. Which I should be able to add my extensions and be under 65. But manual also says that maximum number of elbows is 6, and my intake allready has more than that. Is my idea do able/ safe? What are my other options? I would need to wrap the 5 ft extensions with insulation? I do have a condensate pump in basement. Thanx for any help I can get. I canít afford to have a ďproĒ do it otherwise I would. I can glue pipe just fine, just want to make sure I wonít cause any issues
Need help extending HE furnace vent-b5462a60-5d81-4fa7-932d-bee42e04563c.jpg   Need help extending HE furnace vent-ce70692e-86f5-44ac-9c05-f18a37d6c47c.jpg   Need help extending HE furnace vent-894010fc-cfee-43d9-a7ed-233563b701e4.jpeg
Jeffbriggs18 is offline   Reply With Quote
Furnace vent shammie1 HVAC 3 10-27-2017 11:21 AM
Gas furnace vent joemc3 HVAC 20 02-06-2017 01:15 AM
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Only furnace supply vent in basement? guyver2k HVAC 8 02-26-2012 03:12 PM
wall furnace emits slight warmth at middle/top grilles of front vent while off daluu HVAC 3 02-26-2012 07:42 AM
