Need Help Deciding How To Conceal A/C Electrical In Closet - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-03-2015, 03:59 PM   #1
Rewards Points: 20
Need help deciding how to conceal A/C electrical in closet
I am currently finishing a basement playroom with drywall for our son. There is an alcove area that will be used a closet/storage room for toys. However the lines for the A/C run down from the ceiling and out the wall to unit.
I need to conceal the lines so that if he gets into the closet, little hands won't get into trouble.
My initial thought of course was to build out a small pillar with studs and drywall. With only needing to come out 3-4 inches.
My second thought was to possibly just use some 5 inch corrugated drainage piping and put a slit down the length and fix it around the lines as a faux-conduit. I have extra piping, so its something I have on hand.
Any thoughts. suggestions?
Thanks!
http://s23.postimg.org/4105w9dqz/201...17139_i_OS.jpg
http://s22.postimg.org/ckvmselox/201...30167_i_OS.jpg
bashley83 is offline   Reply With Quote
Old 09-03-2015, 08:40 PM   #2
Rewards Points: 1,746
Probably simpler just to make the whole back of the closet a couple inches forward. If the closet isn't that wide you won't lose much. You could also build the lines into one of the sidewalls of the closet.
ChuckF. is online now   Reply With Quote
Old 09-04-2015, 07:48 AM   #3
Rewards Points: 6,889
And mark the location. One of the very few claims my insurance company paid was when some dumb butt ran a freon line right behind drywall and then the owner wanted curtains mounted there.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 09-05-2015, 10:25 AM   #4
Rewards Points: 153
Hat channel, or you can bend some sheet metal to cover.
eandjsdad is offline   Reply With Quote
Additional fan in closet Tankeray General DIY Discussions 11 06-04-2013 05:05 PM
New Basement Bathroom / Laundry Room Electrical Circuit(s) Rookie11 Electrical 5 12-11-2012 08:52 PM
Electrical loading question jimcorey Electrical 2 12-08-2012 07:27 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 08:15 PM
