Need Advice On Opening Up Diagonal Walls - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By chandler48
Old 10-09-2017, 09:54 PM   #1
Need advice on opening up diagonal walls
I am preparing to move into a new home and the first order of business is to open up the sight line from the kitchen to the great room. There are two small wall sections and a diagonal wall in between them. There is a second taken above and probably roof load. I need advice on how to carry the span over from each opening pictured. I presume it can be best accomplished with 1-2 columns. Any help is greatly appreciated.
Need advice on opening up diagonal walls-5f4bfc4f-5829-4ea0-94dd-bb62bc1107e4_1507600418594.jpg   Need advice on opening up diagonal walls-ae13a050-693b-47f0-917e-6914ae726566_1507600443498.jpg   Need advice on opening up diagonal walls-d6c63da7-95e0-4a9d-8eba-41765f494eab_1507600460885.jpg   Need advice on opening up diagonal walls-760248c2-bc7e-4b28-a17f-76b4af867513_1507600483713.jpg
Marktemp is offline   Reply With Quote
Old 10-10-2017, 06:11 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,028
Re: Need advice on opening up diagonal walls
In a situation like this, it would always be best to get an on site inspection and recommendation from a structural engineer. We can't see what is above the ceiling, and he could make a better determination that we could.
mark sr likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 10-10-2017, 06:28 AM   #3
Rewards Points: 4,796
Something to think about..
Taking out that wall will cause the hardwood floor to need work, maybe even replaced.?
Then you have the ceiling to deal with.?
Electric and lighting.?
ron45 is offline   Reply With Quote
Opening up walls SCharter Building & Construction 3 02-25-2013 09:51 AM
Glow in the dark paint for walls advice lukeja Painting 2 08-18-2012 07:12 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 07:09 PM
Need to Join some walls together. Need advice on a couple of things *Pics* J187 Building & Construction 4 05-20-2006 05:45 PM
