Need Advice On Feature Wall Over Fireplace - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Windows on Wash
  • 1 Post By chandler48
Old 11-01-2017, 06:18 AM   #1
Rewards Points: 22
Need advice on feature wall over fireplace
First of all I would like to thank everyone for the advice on my feature wall in my bedroom. Now I am in the process of doing a feature wood wall over my fireplace in my living room over my fireplace.
The wall over my fireplace is flat and does not stick out like some walls do by the fireplace. The wall has crown molding on it and I was wondering should a section of the crown molding be removed over the fireplace or should I just go up to the molding with the wood feature wall.
Thanks again for any advice.
Partsman19 is offline   Reply With Quote
Old 11-01-2017, 07:05 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,312
Re: Need advice on feature wall over fireplace
It ultimately depends how far up the wall you bring the feature, but in many cases if you’re going to install a decorative wall veneer up to the ceiling, the crown will then be returned into the wall detail.
Jaime296 likes this.
Old 11-07-2017, 05:00 AM   #3
Rewards Points: 22
What is the best tool to use to cut a piece of the crown molding out while installed on the wall. I was thinking of a Dremel but not sure if that would work.
Old 11-07-2017, 05:23 AM   #4
Naildriver
chandler48's Avatar
Rewards Points: 3,660
A multitool and a steady hand would be best. Example: https://www.amazon.com/FMM350QSL-Mut...70_&dpSrc=srch
mark sr likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Fireplace wall ideas cheryl borszich Interior Decorating 14 08-30-2013 06:17 AM
Framing and drywalling fireplace wall sullijos Remodeling 0 10-03-2012 11:00 AM
Need advice on a wall that was moved. racer220 Building & Construction 5 10-25-2011 04:32 PM
advice on expanding doorway in load bearing wall Jordan_Bailey84 Building & Construction 19 08-15-2011 09:33 AM
Corner fireplace wall zif01 Building & Construction 1 08-12-2011 06:53 AM
