Need Advice On Feature Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-25-2017, 06:43 AM   #1
Rewards Points: 22
Need advice on feature wall
Hi all,
I am in the process of putting some shiplap on my master bedroom wall but need some advice on what to do with the crown molding on top and baseboard molding. I put some crown molding on the top of the walls throughout the entire bedroom. The ceiling in the bedroom is popcorn so I removed some of the popcorn and put some white caulking to hide the slight gap between the molding and ceiling on top. I would like to know if I need to either put that molding back up, leave it off and put no molding at all or a different molding. Also, the bottom molding is white...again would I put it back on or leave it off. If I do add it back since the wall is going to be grayish should I stain it to the same color as the wall?
Thanks for any advice.
Partsman19 is offline   Reply With Quote
Old 09-25-2017, 06:53 AM   #2
retired painter
Rewards Points: 1,360
Re: Need advice on feature wall
A pic would be helpful. It can look good with or without crown on that wall. How does the crown end on the adjoining walls?
mark sr is online now   Reply With Quote
Old 09-25-2017, 06:55 AM   #3
Rewards Points: 22
They are mitered to the adjoining walls.
Old 09-25-2017, 07:52 AM   #4
retired painter
Since it's a mitered cut you'll need to either square it off [if the new wall is thick enough] or otherwise figure out how to end the crown where it looks nice ..... if you don't put the crown up on the accent wall.
Old 09-25-2017, 09:27 AM   #5
JUSTA MEMBER
Rewards Points: 3,574
Put the crown and baseboard back up.
It looks incomplete without it.
ED
de-nagorg is offline   Reply With Quote
Non Load Bearing Wall advice ralphv Carpentry 5 06-25-2017 12:23 PM
Structural Advice for Removing Load bearing Wall? sdba Building & Construction 1 05-11-2017 02:16 PM
Advice sought on how best to fit this wall mural Ali101 Interior Decorating 2 05-23-2012 09:37 PM
Load Bearing (point Load) Wall Removal Advice Stringer9 Building & Construction 5 11-09-2010 10:14 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
