Need To Add Bathroom Somewhere? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-03-2014, 12:45 PM   #1
Rewards Points: 302
Need to add Bathroom somewhere?
Hi
I am doing a full remodel basicly a rebuild of my house of last 5 years. I am getting to the end and want to install a 2nd bath. When I framed and finished Master I include a space for a small bathroom. But I didnt have money to finish it so I just drywalled it and am using it as WIC. I had planned on adding a closet across back wall of bedroom once bathroom fixtures were added. Now I dont want to loose that space. Will only have 11x13 master. So now Im back to planning.
Only thing I can think of is to add door into living room so I can loose hallway going to MBD. I really doing want to do this. I already insulated this wall for sound and I still hear tv a little. Plus it is a little weird.
I originally had master bedroom were living room is but living space was too small so I reworked layout.
I installed trusses so there is no load bearing interior walls. The bath that is done has electrical panel on end wall so i dont want to move that wall. I built one big bedroom for 2 little girls and when they got older I was going to wall up in between rooms. So there needs to be a door and closet would be nice. Anything else can be moved.
Any thoughts would be appreciated.
JustinK is offline   Reply With Quote
Old 03-03-2014, 05:40 PM   #2
Rewards Points: 3,130
Sorry, can't help. But I've gotta say, that's one weird floor plan.
Old 03-03-2014, 07:19 PM   #3
Rewards Points: 302
I like to call it unique. Thats what happens when you remodel one room at a time and change your mind a couple times along the way. It works though. Except the one bathroom part.
Old 03-03-2014, 07:33 PM   #4
Rewards Points: 808
Where do you want to lose space?
IslandGuy is offline   Reply With Quote
Old 03-03-2014, 07:38 PM   #5
Rewards Points: 302
laundry area. I would still need a spot for w/d
Old 03-03-2014, 08:03 PM   #6
Rewards Points: 396
Bottom middle, in the space that looks to be between the kitchen and second bedroom. You seem to have a closet bump out into the space so I'd just continue that and put a half bath next to it. (assuming you just want a half bath)
MLMIB is offline   Reply With Quote
Old 03-03-2014, 08:16 PM   #7
Rewards Points: 302
That's the entry. The front door is actually bigger than shown its a double sidelite door so the 5' door takes up most of the 7.5' wide entry. So Not enough room. Thanks though.
Old 03-03-2014, 09:36 PM   #8
Rewards Points: 808
The current layout doesn't allow itself for the "addition" of one thing without losing another thing. If you bumped the master WIC and added a bath back to encompass the laundry area, there's no room for a laundry area elsewhere. Unless you can stack a washer/dryer somewhere in the kitchen. Also, utilizing the laundry area for bedroom bath or closet space eliminates the possibility of the 2nd access door to the kid's bedroom.
Old 03-03-2014, 09:45 PM   #9
Rewards Points: 302
What do you think of adding door into living room eliminating hallway going to master. Is there really a way to sound proof a door and have it look normal ?
Old 03-04-2014, 07:21 AM   #10
I get that. Our log house has a large loft area that is the master suite (bedroom, bathroom, walk-in closet) plus a tv room. No load-bearing walls. My wife changed the entire floor plan as we were building it.
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
Best option for Bathroom Ceiling Paint? tealab Painting 7 04-05-2013 04:49 PM
Columbus Ohio Basement Full Bathroom -Post-Construction Compliance Hermi14 Plumbing 5 03-12-2013 07:11 PM
Rewiring Bathroom & Den heyjoe91 Electrical 4 02-21-2013 04:22 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
