DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Remodeling (https://www.diychatroom.com/f15/)
-   -   Need to add Bathroom somewhere? (https://www.diychatroom.com/f15/need-add-bathroom-somewhere-197228/)
JustinK 03-03-2014 12:45 PM
Hi
I am doing a full remodel basicly a rebuild of my house of last 5 years. I am getting to the end and want to install a 2nd bath. When I framed and finished Master I include a space for a small bathroom. But I didnt have money to finish it so I just drywalled it and am using it as WIC. I had planned on adding a closet across back wall of bedroom once bathroom fixtures were added. Now I dont want to loose that space. Will only have 11x13 master. So now Im back to planning.
Only thing I can think of is to add door into living room so I can loose hallway going to MBD. I really doing want to do this. I already insulated this wall for sound and I still hear tv a little. Plus it is a little weird.
I originally had master bedroom were living room is but living space was too small so I reworked layout.
I installed trusses so there is no load bearing interior walls. The bath that is done has electrical panel on end wall so i dont want to move that wall. I built one big bedroom for 2 little girls and when they got older I was going to wall up in between rooms. So there needs to be a door and closet would be nice. Anything else can be moved.
Any thoughts would be appreciated.
http://i564.photobucket.com/albums/s...1.jpg~original
md2lgyk 03-03-2014 05:40 PM
Sorry, can't help. But I've gotta say, that's one weird floor plan.
JustinK 03-03-2014 07:19 PM
I like to call it unique. Thats what happens when you remodel one room at a time and change your mind a couple times along the way. It works though. Except the one bathroom part.
IslandGuy 03-03-2014 07:33 PM
Where do you want to lose space?
JustinK 03-03-2014 07:38 PM
laundry area. I would still need a spot for w/d
MLMIB 03-03-2014 08:03 PM
Bottom middle, in the space that looks to be between the kitchen and second bedroom. You seem to have a closet bump out into the space so I'd just continue that and put a half bath next to it. (assuming you just want a half bath)
JustinK 03-03-2014 08:16 PM
That's the entry. The front door is actually bigger than shown its a double sidelite door so the 5' door takes up most of the 7.5' wide entry. So Not enough room. Thanks though.
IslandGuy 03-03-2014 09:36 PM
The current layout doesn't allow itself for the "addition" of one thing without losing another thing. If you bumped the master WIC and added a bath back to encompass the laundry area, there's no room for a laundry area elsewhere. Unless you can stack a washer/dryer somewhere in the kitchen. Also, utilizing the laundry area for bedroom bath or closet space eliminates the possibility of the 2nd access door to the kid's bedroom.
JustinK 03-03-2014 09:45 PM
What do you think of adding door into living room eliminating hallway going to master. Is there really a way to sound proof a door and have it look normal ?
md2lgyk 03-04-2014 07:21 AM
I get that. Our log house has a large loft area that is the master suite (bedroom, bathroom, walk-in closet) plus a tv room. No load-bearing walls. My wife changed the entire floor plan as we were building it.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
