Moving A Toilet - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-26-2017, 06:16 PM   #1
BigAlec
Rewards Points: 14
moving a toilet
Hello
I want to move a toilet to the left by 3 ft but the existing setup is it is in a bulkhead
this is on the second floor I don't want to extend the bulkhead as it will be ugly so I was looking to add an 90 elbow and then extend to the 3 ft i need within the original ceiling joists
the reason for the bulkhead is it transverses a joist
the stack is vented staight up
this means having 3 ..90 degrees elbows and having a 3/4 drop ? are 3 90degrees elbows ok? I will be 5 ft from the vented stack using 4" poly
see attachment
there is no place to add a clearout access as this will all be beneath a shower I intend adding thus the need to move the toilet
any ideas would be appreciate
thanks
Alec
bigalec is offline   Reply With Quote
Old 05-25-2017, 10:30 AM   #2
Professional
Rewards Points: 188
Re: moving a toilet
From where I'm sitting that looks legit (that might change if I could stand in the room!). And actually it looks like an easy fix because often relocating a toilet is not possible. Good luck with your project!
Str8AheadInc is offline   Reply With Quote
toilet leak issue: need advice michaelw Plumbing 5 07-01-2015 08:18 PM
moving a toilet over slightly (ideally 100ml) p&lrenos Plumbing 2 05-27-2012 12:00 PM
Moving toilet 12 feet, unsure about venting sputnik62 Plumbing 11 05-10-2011 03:32 PM
moving toilet farrington135 Plumbing 5 11-19-2005 04:29 PM
