Metal Stud Construction Needs Noise Reduction - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-05-2016, 12:02 PM   #1
Rewards Points: 26
Metal stud construction needs noise reduction
Not sure this is the right place for this so if it's not, apologies.
Bought a steel frame constructed house and we're having serious issues with noise transmission.
My end goal is to be able to run saws in the garage and not have them be heard in the adjoining master bedroom. Currently, you can hear the sound of voices in the garage from the MB. Put your ear against the wall and you can make out words sometimes. It's horribly noisy.
I've looked at a few options like different types of insulation, taking down the drywall on the garage side putting eggshell foam in the cavities, hanging cotton towels stretched over wood frames on the walls, hanging wafer board, etc. but I'm not sure any of it will work which is why I need some feedback. I've also recently discovered resilient channel but I can't seem to find an answer as to its effectiveness with metal studs.
I'm not looking to break the bank, but I would love to not structure my project time around nap/bed time.
Thanks in advance
49Unbeaten is offline   Reply With Quote
Old 12-05-2016, 01:18 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,216
Re: Metal stud construction needs noise reduction
What does the wall construction consist of that is there now. You are going to be looking at, at least, offset wall, double drywall, etc.
Old 12-05-2016, 01:19 PM   #3
http://www.wallandceilingbureau.org/...0-%20Final.pdf
Old 12-05-2016, 04:01 PM   #4
jlhaslip's Avatar
Rewards Points: 708
Might need to add some "sound bar" ( Z bar) and another layer of drywall.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 12-05-2016, 04:14 PM   #5
Rewards Points: 26
Windows, thank you very much for the link. Lot of good info in there. Base on the link it doesn't sound like much of anything is in the wall cavity but I haven't actually looked. We've owned this house for a year now and the the more I learn about it, I wouldn't be at all surprised if there was nothing in there.
JL, thanks for the recommendation. I'll so some research.
Old 12-06-2016, 09:46 AM   #6
Rewards Points: 17,882
http://www.soundproofingcompany.com/...roofing-walls/
Tags
metal studs , noise reduction
Door Sweep for Noise Reduction bluetiger77 Windows and Doors 2 11-11-2014 03:39 PM
Foam tape for noise reduction? vent extension? drywalling ceiling just_a_guy Drywall & Plaster 0 10-22-2014 07:46 PM
construction noise & neighbors acerunner General DIY Discussions 37 12-17-2012 08:06 AM
Metal building construction Mark Harvey Building & Construction 2 01-24-2011 04:42 PM
Cricket Construction on Metal Roofing? Lion Gordon Roofing/Siding 1 07-20-2005 09:59 PM
