Master Closet/bathroom/shower Project - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-11-2016, 08:35 PM   #1
Rewards Points: 8
Master closet/bathroom/shower project
In the process of demoing our closet/bathroom/shower that's directly connected to our master bedroom. The initial though process was to find a way to improve our closet, this quickly turned into a discussion of 'why don't we just move the wall and redo everything?'. This area has always been a black eye for our house since moving in. The whole area is small and layout changes are minimal. It'll basically be a gut of everything, build new wall, and rebuild out the space.
Current Floorplan (right) vs the new on the left. I'll be moving the wall (non load bearing) into the room approximately 14". It's 14" because that's all the room I have to work with given the entry of the room.
http://a67.tinypic.com/9ifpef.jpg
http://a64.tinypic.com/21jabzr.jpg
This view is from the hallway looking into the master bedroom entry. The door opening is now 48"" will be downsized to fit a standard 32" door.
http://a64.tinypic.com/11i1rte.jpg
The following pictures are what the spaces look like. These pictures are from our initial walk through when we bought the home.
http://a68.tinypic.com/10ykq6o.jpg
http://a66.tinypic.com/9tih02.jpg
http://a65.tinypic.com/23wv12g.jpg
http://a66.tinypic.com/z4ahh.jpg
The things I'm looking forward to removing:
--The 80's gold mirrored pocket doors
--The black toilet AND sink
--The cedar planking completely covering the closet walls
--The ~10" of wasted spaced that's firred out behind the shower
--The soffit above the vanity
--The vanity with slate tiled top
As of now I plan to do everything DIY with the exception of tape/mud/texture and carpeting in the master bdrm.
kramer99 is offline   Reply With Quote
Old 06-11-2016, 08:38 PM   #2
Rewards Points: 8
Re: Master closet/bathroom/shower project
These are the ideas I am originally planning on.
Easy/cheaper option on the top/left of a full wall in shower with a walk-in opening.
Preferred/better option on the bottom/right with a half wall and glass atop.
Second option would have a similar layout as this picture
This is my plan for the closet. 2 walls will have double layered rods with corner shelving with additional sleving against the other non-entry wall.
Something similar to this picture
Since I'll be removing the hideous golden mirrored pocket doors my plan would be for double 'barn' doors for the extra wide entry into the bathroom. Something similar to the below picture, but it'd be double doors
Old 06-11-2016, 08:39 PM   #3
Rewards Points: 8
I had another plan drawn up that I didn't post originally but we're still considering.
http://a63.tinypic.com/14oauqf.jpg
I do think it'd greatly improve the layout and flow of the space but I did have a few concerns in doing so.
--The biggest issue is that it would require moving the toilet drain (slab foundation).
--Moving the water closet further out would take more space of the actual room.
--The jig/jag wall when entering the room may be weird and create an odd corner nook entry
--The 'hallway' nature entry into the bathroom
Old 06-11-2016, 08:40 PM   #4
Rewards Points: 8
Demo day
Closethttp://a63.tinypic.com/2drrxfp.jpg
Slate tile floorhttp://a66.tinypic.com/dh97p2.jpg
Shower (lots of wasted/open space above and behind shower)http://a65.tinypic.com/hsq0xi.jpg
http://a67.tinypic.com/34q8lj5.jpg
http://a65.tinypic.com/2nbyhrk.jpg
They were nice enough to put in shut off valves http://a65.tinypic.com/4v4g0p.jpg
The mortar based pan has been slow/hard work http://a65.tinypic.com/2wnb7so.jpg
My new carport & workshop project mgp roofing Project Showcase 64 01-13-2014 11:57 AM
Removing master half bath to extend main bath ryanb4614 Plumbing 18 08-27-2011 07:21 AM
Timbertech Radiance Rail project Ranger1227 Project Showcase 7 07-29-2011 12:59 PM
Extra Empty Room Attached to Master ryanb4614 Building & Construction 6 07-27-2011 04:04 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
