Marble Tiles On Non-concrete Surface? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-07-2018, 02:50 PM   #1
Rewards Points: 6
Marble tiles on non-concrete surface?
We are renovating our 1890 farmhouse and adding an extension to it. In this extension will be a new stand up shower for which we have bought some 12 x 12 marble tiles. The beginning of the project will be on a wood floor, but we just need to know the steps for making the right foundation and slope for the floor of the shower. The tiles are not the flexible smaller squares, but the 12 x 12 solid slabs. If anyone knows the correct procedure for this please educate us?
Sharkys Girl is offline   Reply With Quote
Old 01-07-2018, 03:06 PM   #2
Guapo
Rewards Points: 11,950
Re: Marble tiles on non-concrete surface?
AFAIK, you still need a mud job. In other words, the slope is created with mortar. Search youtube for some videos. Are the sides of the shower going to be tiled too?
Guap0_ is offline   Reply With Quote
Old 01-07-2018, 03:10 PM   #3
Rewards Points: 6
it will all be tiled, but do we need sheetrock then hardibacker? or can we use just straight hardibacker without sheetrock behind it?
Old 01-07-2018, 03:23 PM   #4
Naildriver
chandler48's Avatar
Rewards Points: 3,676
Here's a tutorial on making the shower pan. You will be hard pressed using 12x12 tile on the floor since they don't bend to the contour of the slope. Using 12 x 12 sheet tiles of 2x2 tiles is better. http://floorelf.com/how-to-create-a-shower-floor-part-1
On the walls, you would insulate, of course, and apply a 6 mil vapor barrier, then conventionally use either Durock or equivalent on the walls. No sheetrock. More expensive systems (Schluter) exist and you can research them if you like.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 01-07-2018, 03:36 PM   #5
Rewards Points: 6
Thank you!!
Tags
flooring advice , marble shower , renovations , shower floor , solid marble tiles
Concrete Dusting (soft dusty surface) Garrben Concrete, Stone & Masonry 1 11-13-2017 03:58 PM
Raising concrete floor surface cdet1997 Flooring 9 09-25-2017 02:05 PM
Laying dura ceramic tiles on concrete monte Flooring 25 03-11-2013 09:31 PM
Marble Tiles Cracking gshukert Remodeling 5 05-07-2012 03:54 PM
