Load Bearing Walls? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-10-2016, 08:28 AM   #1
Load bearing walls?
Looking to remove a wall between kitchen and living room! Assumed it was a load bearing wall so I had a SE come out and write a report to remove the wall. Then had contractors come and give estimates! The only person to actually go into the attic and look was the 3rd contactor and he says it's not load bearing with the truss system I have!! Need help determining if it is or isng load bearing!!! Have pics upon request as I started opening up the drywall to see what I'm working with! Thanks in advance!
Nate1985 is offline   Reply With Quote
Old 01-10-2016, 08:57 AM   #2
Civil Engineer
Rewards Points: 5,246
I am guessing the term SE means structural engineer. Any structural engineer with a license should look in the attic to see what is bearing on the wall. Assuming you paid the SE, and had a contract, I would contact the SE and ask them for a no cost update to their report based on the attic condition.
Old 01-10-2016, 09:05 AM   #3
Yea a structural engineer...he assumed it was bearing and took some measurements..let me ask this, if the wall i want to take out it directly above the main beam in the basement but is not in the center of the first level floor...it's offset 2 ft to the right of,the peak (cathedral ceilings), does it sound load bearing?
Old 01-10-2016, 09:06 AM   #4
And roof structure is a truss system!
Old 01-10-2016, 11:55 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 748
Nate,
It would help if you post a few pics of the trusses. We removed a wall separating the kitchen/dinette with the living-room/dining. I was worried it was bearing, but it isn't.
The trusses span about 25 ft. and I learned the bearing points are the two contact points at the perimeter, the center walls did almost nothing and were not necessary. Of course someone has to inspect and certify/guarantee it.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 01-11-2016, 03:09 AM   #6
I can't get pics to load
Old 01-11-2016, 03:30 AM   #7
Truss above cathedral ceiling in living room looks like this (scissor truss)....once It gets to the other side of the house where the cathedrals are gone the truss changes a bit...the wall I want to take out sits about 2 ft to the right of the peak
Old 01-11-2016, 04:23 AM   #8
This is the layout of,the 3 rooms..the wall between the DR and KT is non load bearing and it's gone almost out already...the one with the red arrow is the wall in question...it's running perpendicular to the trusses and that wall is directly on top of the main beam of the house
Old 01-11-2016, 08:16 AM   #9
Rewards Points: 144
So you had a SE and contractors (plural) come out and visually inspect your home with differing opinions?Didn't like the outcome so decided to get advice on an internet forum? How's that work?
Spent years dealing with SE;s on a daily basis .They are not always correct but bottom line is if he wrote a report and put a stamp on it nothing the contractors say will mean diddly to the inspector.
mako1 is offline   Reply With Quote
Old 01-11-2016, 08:28 AM   #10
Rewards Points: 144
Truss system has little to do with load bearing.I can have free span trusses designed for a 40' span or I can have trusses designed for a 40 foot span with a load bearing wall at 12' or 20'.I recently had some 43' 11" trusses designed with a 8' cantilever on one end.
I don't know the details because you gave few but it's possible the SE didn't go into the attic because he obtained the original plans for the house from the building dept. and reviewed them before coming out.
Old 01-11-2016, 10:12 AM   #11
I had the SE out and assumed it was load bearing...the contractors I had come out, 3 of them, said it wasn't load bearing..I'm going to call the SE today and see if he pulled the house plans because he never mentioned that to me
Old 01-11-2016, 06:21 PM   #12
Tileguy
JazMan's Avatar
Rewards Points: 748
Well, sure. That's what you hired him for. You need his certification either way.
Makes no difference, the beam in the basement is supporting the main floor.
Jaz
Old 01-11-2016, 06:27 PM   #13
Thats what I've been reading...and,the purpose of me coming on here is to learn about all this...not to try and hear people tell me what I want to hear lol
Old 01-11-2016, 06:50 PM   #14
Civil Engineer
So let's review the bidding. The definition of a load bearing wall is one that holds up more than its own weight. The load typically comes from joists that bear on the wall, another wall directly above the bearing wall, or framing elements that bear on the wall. There is NO WAY to determine if a wall is load bearing without physically inspecting the space above the wall to determine if any framing elements bear on the wall.
I find it amazing that a registered professional structural engineer would declare a wall to be load bearing without verifying the conditions above the wall. Even if the engineer had stamped, as built plans, he still needed to go into the space above to verify that the house was actually built the way the plans show.
You stated that the engineer was a structural engineer. You did not note if you had a contract with the individual, or whether the engineer was paid for services. If you had a contract, and/or if you paid this person, you have a right to demand that they come back at their own expense to update the report based on actual conditions in the house. No one on an internet chat forum can tell you with certainty whether that wall holds up anything above without looking at the framing, but that is what you presumably paid for, so a call to the engineer would be in order.
Old 01-11-2016, 06:53 PM   #15
Agreed!!! And I did pay for his services! I called and left a message..no answer!
Wine rack as load bearing wall? lisa7932 Building & Construction 5 02-27-2012 12:53 AM
Finding Load Bearing Walls Dane Hitchins Building & Construction 15 05-14-2011 10:09 AM
Load bearing walls Brandon760 Building & Construction 5 03-02-2011 08:34 PM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 04:33 PM
Load Bearing walls????? DoubleDD Building & Construction 1 11-23-2009 09:31 PM
