Is This A Load Bearing Wall, Solution? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-07-2018, 10:09 PM   #1
Rewards Points: 6
Is this a load bearing wall, solution?
I want to remove two walls in this home that I just purchased but I'm not if it's load bearing. I have shown where the beams are relative to the old wall and pictures of the attic. The wall is underneath the right side of where the ceiling rafters join and lap. What are my options for removal of this wall?
Is this a load bearing wall, solution?-remodeled.jpg   Is this a load bearing wall, solution?-connections.png   Is this a load bearing wall, solution?-wallbeams2.png   Is this a load bearing wall, solution?-wallbeams.png
Kaminsknator is offline   Reply With Quote
Old 05-07-2018, 10:12 PM   #2
Rewards Points: 6
Re: Is this a load bearing wall, solution?
More information
Shows the beam locations relative to where the wall used to be.
Old 05-07-2018, 10:25 PM   #3
retired framer
Rewards Points: 18,522
It is hard to tell if the valley and gable system at the end would be self supporting, even if it was built to be self supporting theses things have a habit of sagging over time. If the ceiling joists over lap on a wall the wall is bearing half the weight of the ceiling. You would have to replace that with a beam below or in the ceiling.
Old 06-01-2018, 02:06 PM   #4
Rewards Points: 58
It's tricky to tell if the walls are load bearing. I'd contact an engineer and ask for their advice just to be on the safe side.
interiordesign2 is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Load bearing wall? renntecher Building & Construction 2 02-04-2013 01:35 AM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 06:45 PM
Is this Load Bearing Wall remodel-virgin Building & Construction 16 05-11-2009 04:25 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
