Load Bearing Wall Removal - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By 3onthetree
  • 1 Post By Nealtw
Old Yesterday, 12:51 PM   #1
Rewards Points: 6
load bearing wall removal
I am in the process of moving a load-bearing wall!
The tricky thing is that it is 2' away from the upstairs wall. (the kitchen is popped in 2') stupid builder.
The span is 15' and my engineer has spec out a 6 3/4 x 9 glulam.
My question is how far can I safely cut the floor joist back to accommodate the new beam? ( it will be a flush beam on both sides) ceiling and floor.
Or should I just stab it on the outside with hangers?
The engineer also wants me to install 2 micro- lams near the wall. I was just going to cut the joist as close as possible and slip them in with hangers.
I'm also doing the wall next to it that is the dining room.
load bearing wall removal-20191108_094423.jpg   load bearing wall removal-20191108_094358.jpg   load bearing wall removal-20191108_094411.jpg
j&sk is offline   Reply With Quote
Old Yesterday, 01:04 PM   #2
retired framer
Rewards Points: 24,006
Re: load bearing wall removal
It reads like the beam is sized to fit in place of the joists.
You are supporting the upper wall and removing the lower wall ?
Did the engineer tell you how long the beam should be.
Only put a beam in a hanger if the engineer gave you the number for the hanger he wants.
Do not use flat bottom gables with scissor trusses.
Old Yesterday, 01:35 PM   #3
Rewards Points: 6
The design is that the joist hangers will be placed on the side of the glulam to pick up the weight of the floor upstairs.
So I could just take off the ledger board and put up the beam or I could cut back the floor joist the additional 4 1/2"
Just nerves about doing this!
The wall will stay in place until all glulams are installed!
Old Yesterday, 02:02 PM   #4
retired framer
Yes but, but ,but.
It appears that your joists are not cantilevered but just shorts tied into the joist on top of the wall. If I am right the only support for the outside wall is the rim joist. Am I right and did the engineer see that detail.
If they were cantilevered your plan would be fine but if maybe no?
Old Yesterday, 02:08 PM   #5
retired framer
Old Today, 02:38 AM   #6
Rewards Points: 6
The floor joist are cantilevered 3 1/2 feet back into the kitchen attached to (2) 2x10.
So when or if I cut the floor joist back, to put in under the upstairs wall. It will just be the plywood and exterior wall holding itself up for that 6 3/4 space until the beam is installed. (which would be as soon as possible)
Does this make sense?
Old Today, 09:29 AM   #7
Hammered Thumb
Rewards Points: 206
The assumption is your engineer has covered all the bases. But in order to get the best advice, its very confusing to me from your words and pictures. So marked up pic to avoid word salad myself.
Where does the glulam go? Microlams? Where's post support? Where is the dining room you speak of changing structure?
What is exactly holding up the 2nd floor wall besides a rim joist with no column at the corner? The 3.5' joists of the "cantilever" sure look to not sit on top of the kitchen wall (cantilever means the main floor joists extend continuously over the outer wall for an overhang). That means they are just levitating up there by magic.
Why has a new slab been extended beyond the outermost wall (water ponding)? Is it thickened (assuming no frost) where I think the new exterior wall is going? Looks like CA or AZ, any seismic considerations here?
Windows on Wash and Nealtw like this.
3onthetree is offline   Reply With Quote
Old Today, 11:12 AM   #8
retired framer
I looked pretty close, and did not see plywood behind the stucco.
What will hold the beam up on the left hand side?
If you remove the rim and cut the joists for a beam there will be nothing under the wall itself, So all the weight is hanging on stucco and drywall.
Old Today, 11:29 AM   #9
retired framer
I think we need more of this story.
Gymschu likes this.
Old Today, 08:28 PM   #10
Usually Confused
lenaitch's Avatar
Rewards Points: 58
Would not a proper engineer's report specify not only what material to use but how to use it? I've seen them specify things like size of nails and nailing patterns.
I'm with Neal, that rim joist looks continuous and floor joist looks like stubs unless I missing something.
_________________________________________
Sic Itur at Astra
lenaitch is offline   Reply With Quote
