Is This A Load Bearing Wall? - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-24-2016, 02:13 AM   #1
Rewards Points: 4
Is this a load bearing wall?
Alright. I have this wall i'd like to get rid of, it separates kitchen from dining/living. We have some 2x10s spanning above the said wall. Few pictures attached. Also, confused on this big ugly support beam, i'm thinking i have a couple of directions going on in the ceiling here
Is this a load bearing wall?-imag1323.jpg   Is this a load bearing wall?-imag1332.jpg   Is this a load bearing wall?-imag1334.jpg   Is this a load bearing wall?-imag1336.jpg
DavyBravo is offline   Reply With Quote
Old 08-24-2016, 05:55 PM   #2
Rewards Points: 1,036
Re: Is this a load bearing wall?
http://www.diychatroom.com/f19/parti...g-wall-371986/
Mingledtrash is offline   Reply With Quote
Old 08-26-2016, 09:47 PM   #3
Rewards Points: 1,832
I'm toward load bearing, but a structural engineer would be best either way.
Jump-start is offline   Reply With Quote
Old 08-27-2016, 07:28 AM   #4
Rewards Points: 2,438
Your ceiling joists are on that wall, based on photo. So for now it is a load bearing wall. It also depends on how that wall is supported underneath. You have to open up more of the ceiling to see how those joists are supported and what is under the wall. The dropped ceiling (not the dropped box) suggests a substantial beam. Your joists could be hanging on those beams but, as always, eye inspection is only answer for anything more involved than window or door header.
carpdad is online now   Reply With Quote
Load bearing wall? renntecher Building & Construction 2 02-04-2013 01:35 AM
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 05:35 PM
Looking into removing a load bearing wall IRuehl Remodeling 5 07-02-2011 03:39 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 06:45 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
