Load Bearing Studs? - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-07-2016, 08:04 AM   #1
Rewards Points: 44
Load bearing studs?
I'm taking down a wall that made a small closet. Upon opening the drywall up I was surprised to see two sets 2x4s. Can these be taken out? Along with the 2x4 on the ground?
I'm very very to projects like this.
Thank you for your help! ?
Load bearing studs?-image_1465304589338.jpg   Load bearing studs?-image_1465304605976.jpg
luckiestman139 is offline   Reply With Quote
Old 06-07-2016, 08:07 AM   #2
Rewards Points: 44
I'm very new* to projects like these
Old 06-07-2016, 09:56 PM   #3
Rewards Points: 17,890
Re: Load bearing studs?
Not enough info.
Pictures are taken to close up.
One place you say your taking down a wall, then you mention it's a closet.
Need to be looking in the attic and below that wall to see if if it's a supporting wall.
Just looks like there may have been a door there at one time, or they added a jack stud when they went from plaster to drywall so they had a nailer to attach the drywall to.
Identifying Load Bearing Posts Reader1 Remodeling 3 06-10-2016 08:47 AM
Knee wall - load bearing pineapplemsw Carpentry 13 04-02-2013 02:38 PM
cutting 2 adjacent studs in load bearing wall txbiker Building & Construction 1 02-18-2013 09:50 PM
Romex around or through load bearing wall studs fredm54 Electrical 31 05-15-2012 12:10 PM
Load Bearing wall or not? Dennis6950 Remodeling 5 02-01-2011 08:34 PM
