Load Bearing Beam - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-22-2014, 11:22 AM   #1
Question
Load Bearing Beam
We are doing a project in our home & are going to put a post to bear the weight on load bearing wall. Does the post need to go from floor to ceiling or can we attach the beam to existing half wall (we are making it a pony wall) thank you so much!
Ambermartin is offline   Reply With Quote
Old 07-22-2014, 11:52 AM   #2
Rewards Points: 144
Not a lot of info in your post.In general the post does need to go floor to ceiling and have something to bear on from below.
.Single story?Basement"Concrete slab?
Have you consulted an engineer?
Where are you located?
Impossible to answer your question with the info given.
mako1 is offline   Reply With Quote
Old 07-22-2014, 12:02 PM   #3
Single story, concrete slab in Orange County CA. Thank you.
Old 07-22-2014, 12:46 PM   #4
Rewards Points: 144
CA has some very strict building codes from what I have heard.Best to check with your building dept. who will probably make you get a permit and send you off to an engineer.Concrete slab will make it easier,maybe
Old 07-22-2014, 12:50 PM   #5
Thank you so much for your help!
Old 07-22-2014, 02:02 PM   #6
Residential Designer
AndyGump's Avatar
Rewards Points: 868
Send a message via Skype™ to AndyGump
Depending on the scope of the project you may need an engineer to calculate the size of the beam and the post(s), the connections to each and the size of the existing foundation or a pad under existing foundation location plus other factors.
For a permit the city or county will want plans for sure.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 07-22-2014, 08:16 PM   #7
Civil Engineer
Rewards Points: 5,246
I had a really hard time understanding your post. Maybe I am tired, but you seemed to jump from a load bearing wall to a post to a beam. I could not tell what exists, what you are proposing, what you are supporting, and what the purpose of the post (column) is. Maybe a picture, and a clear description of what you have and what you want, would help considerably.
Tags
load bearing wall support
Need help with load bearing wall removal... Huggins90 Building & Construction 2 01-24-2013 08:06 AM
no support under load bearing wall? foxmanb Building & Construction 1 03-26-2012 11:04 AM
Help calculating beam load OniKoroshi Building & Construction 13 03-22-2012 09:52 PM
Wine rack as load bearing wall? lisa7932 Building & Construction 5 02-27-2012 12:53 AM
Beam Load Ron Building & Construction 5 09-17-2006 06:28 AM
