Leveling Shower Door - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-13-2017, 05:48 PM   #1
jkk
Rewards Points: 317
Leveling shower door
Trying to update shower door. Base is slightly off level so the shims provided are insufficient. I want to find a replacement shim material, a firm rubber in white or clear. Any suggestions?
jkk is offline   Reply With Quote
Old 03-19-2017, 09:44 AM   #2
RickMacKay's Avatar
Rewards Points: 114
Re: Leveling shower door
Plexiglass. It comes in different thicknesses, and can be cut to the right size.
RickMacKay is offline   Reply With Quote
Old 04-02-2017, 06:40 PM   #3
Professional
Rewards Points: 188
Use tiling shims/wedges you can find at any box store then silicon the the heck out of it so your silicon also provides support. Once you have it secure where you like it you can do a finish bead of silicon that wont be an eyesore and only you and maybe atrained eye or two will ever see it again. Only other way is to replace or re-level the tub.
Str8AheadInc is offline   Reply With Quote
Installing Shower Door Not Quite Wide Enough diynorml Kitchen & Bath Remodeling 6 09-20-2014 02:18 AM
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 06:50 AM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 09:00 PM
Leveling the refrigerator VS: Door closing SanDiegoPaul Appliances 14 12-10-2010 10:43 AM
