LED In Concrete Pour Step - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-21-2015, 12:26 PM   #1
Rewards Points: 8
LED in Concrete Pour Step
I have a LED step light that mounts in a standard single gang electrical box 2 3/4" x 4 1/2". All the boxes I have found are not specifically listed for use in concrete pour. Does anyone know of a box (cast or plastic) that has this rating. UL labs post that aluminum alloy boxes are not protected unless protected by asphalt paint or equivalent. I would not like to go that way if possible.
dapperdan is offline   Reply With Quote
Old 09-21-2015, 09:23 PM   #2
Rewards Points: 996
i would use a plastic box with plastic conduit. all sealed with caulk. and tape the opening where it meets the form. care needs to be taken so concrete doesn't leak in.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Redneck Russell (09-22-2015)
Old 09-21-2015, 09:39 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
how about a single gang masonry box:
Old 09-22-2015, 08:18 AM   #4
Redneck Russell's Avatar
Rewards Points: 16
The plastic box would be great seeing it wouldn't have rusting issues later.
Redneck Russell is offline   Reply With Quote
Old 09-22-2015, 09:09 AM   #5
Rewards Points: 8
Wink
Thanks for the good ideas. The masonary box is not allowed under code due to the concrete being in direct contact with earth. It would have to be a cast iron. The plastic will work and I did find a Carlon box that is rated for concrete pour Type FSS. The suggestion to tape the box at the form is great. Thanks again!
Old 09-22-2015, 05:16 PM   #6
nap
You talking to me?
nap's Avatar
I presumed you were in a place where the NEC was applicable. Sorry. Under the NEC we can use stamped steel boxes in concrete as long as they are rated for the use. Dang, if everything had to be cast I could never have put in the thousands upon thousands of feet of Walkerduct I have put in concrete floors.
here is an example of a concrete rated floor box
I guess that would not be allowed where you are.
Old 09-23-2015, 09:33 AM   #7
Rewards Points: 8
Thanks for the response!
Old 09-25-2015, 09:35 AM   #8
Rewards Points: 8
On the posting of the concrete box and Walker Duct it is true they both can be installed in a concrete pour but not in a ground floor slab that is in direct contact with earth. I too have installed many of these in a concrete pour in multi-floor buildings. (National Electric Code) It seems I have found an application that is not very common as most LED and other step lights are sold with a cast box that fits the fixture but is not the exact same size as a standard 1-G electrical box with standard mounting screws! LOL!
Old 09-25-2015, 04:36 PM   #9
nap
You talking to me?
nap's Avatar
dapperdan;2514697]On the posting of the concrete box and Walker Duct it is true they both can be installed in a concrete pour but not in a ground floor slab that is in direct contact with earth.
what code section are you referring to for this.
Concrete step repair roboken Concrete, Stone & Masonry 6 04-19-2015 10:54 AM
how to pour concrete into a hole tcabaco Concrete, Stone & Masonry 10 03-25-2015 11:40 AM
Pour new concrete over garage entrance dip Tonyski54 Concrete, Stone & Masonry 5 01-22-2015 10:14 AM
To pour concrete ove asphalt or not to pour concrete over asphalt. murph2255 Concrete, Stone & Masonry 15 03-10-2013 07:25 AM
