Laundry Room Cabinet Re-do - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-03-2016, 03:17 PM   #1
Rewards Points: 247
Laundry room cabinet re-do
We are looking at replacing our laundry room cabinets, changing them from standard depth to 24 inch deep cabinets so it is easier to reach them given the size of our new washer and dryer. The room is 90" long, 66" across 95" high. Washer and dryer are 32 deep with 7 inch clearance behind them for hoses and exhaust. There is a laundry sink also
Because of the depth of the new cabinets, we will need to support them. It has been suggested to us that panels going from the bottom of the cabinet to the floor be used, but we are worried that it will be difficult, if not impossible, to move the washer and dryer out for repair or replacement.
We have talked about building a soffit, or maybe adding braces to the ceiling to help support. I am attaching some pics. Please offer some ideas. We also do not want to move fan or light if possible. thanks.
Ranger1227 is offline   Reply With Quote
Old 09-24-2016, 04:34 PM   #2
Rewards Points: 70
Re: Laundry room cabinet re-do
I'm tackling a similar project and would like some ideas as well. Following this!
ThatTreeGuy is offline   Reply With Quote
Old 09-25-2016, 07:32 AM   #3
Rewards Points: 2,490
Best would be build out a frame wall so you can attach 12" deep cabinet. Don't know if 24" deep cabinet can be suspended with the backing only, unless it is made for legless install.
Easier if your ceiling joists run cross wise to your cabinet wall but if not, you may have to put blockings in the ceiling or frame the bump out that is reinforced with internal web of ply or braces.
carpdad is offline   Reply With Quote
AFCI breaker tripping in laundry room esahlin Electrical 11 11-27-2014 07:40 AM
Laundry Room Lighting Options miamicuse Electrical 6 07-19-2014 08:02 PM
Laundry room and bath question herdfan Electrical 3 10-27-2013 05:09 AM
Need a foundation in my laundry room sweetfarm Building & Construction 14 09-06-2012 09:49 PM
occasional sewer gas smell in laundry room nebben Plumbing 3 03-25-2007 10:35 AM
